Qr code generator for solidworks drawing
Library for macros
Ömür Tokman
x 972
x 328
Unread post by Ömür Tokman »
Hello everybody,
This is the macro I've been wanting to make for a while.
First of all, I would like to remind you! I am not a programmer, the macro I made is to meet my needs. And it works well enough to meet my needs for now.
It would be great if someone who understands the software could fill in the shortcomings of the macro.
It adds the text written in the textbox to the page as a QR code.
The reason I went with the macro is that it is a single file, does not require installation and I want to write only with VBA. The address where I downloaded the QR code generating module is written on the module page. Does not require internet.
As I said at the beginning, this macro is just to meet my basic needs. "Be sure to test it!" I'm sharing it in case anyone wants to improve it.
QrCodeInsert.swp
(470 KiB) Downloaded 131 times
gupta9665
Answers: 20
x 384
x 415
Re: Qr code generator.
Unread post by gupta9665 »
Thank you for sharing :)
Ömür Tokman
x 972
x 328
gupta9665 wrote: Mon Oct 02, 2023 1:55 pm Thank you for sharing :)
Actually i thank you. This is such a small thing compared to what you have done for us. Mr. Gupta I learned a lot from you.
x 2189
x 1890
Ömür Tokman wrote: Mon Oct 02, 2023 8:12 am Hello everybody,
Awesome work Omur! I might give it a try and see if we could replace our bar codes with these.
Ömür Tokman
x 972
x 328
AlexLachance wrote: Mon Oct 02, 2023 2:41 pm Awesome work Omur! I might give it a try and see if we could replace our bar codes with these.
I'm looking forward to your return, my mate.
Frank_Oostendorp
x 177
x 217
Re: Qr code generator for solidworks drawing
Would like to test it, but seems missing the QRGen file.
Ömür Tokman
x 972
x 328
Frank_Oostendorp wrote: Tue Oct 03, 2023 4:01 am Would like to test it, but seems missing the QRGen file.
You don't need to add any references.
That reference is from a different attempt.
I added a module to create a qr code, but if you need to add it too, I'm adding it here.
https://github.com/wqweto/VbQRCodegen
VbQRCodegen-master.zip
(17.57 KiB) Downloaded 99 times
Frank_Oostendorp
x 177
x 217
(Thanks, sorry but it throws another error. Let's see if Alex can test it.)
After clearing the select box of the missing reference, runs great. Good job.
Ömür Tokman
x 972
x 328
Frank_Oostendorp wrote: Tue Oct 03, 2023 5:52 am (Thanks, sorry but it throws another error. Let's see if Alex can test it.)
Sorry, I didn't quite understand, is it working smoothly now?
Frank_Oostendorp
x 177
x 217
Ömür Tokman wrote: Tue Oct 03, 2023 6:37 am Sorry, I didn't quite understand, is it working smoothly now?
Yes, runs smoothly now.
Ömür Tokman
x 972
x 328
Frank_Oostendorp wrote: Tue Oct 03, 2023 7:08 am Yes, runs smoothly now.
Thank you very much for the feedback. It's nice to be useful to someone, the qr code link is nice.
Frank_Oostendorp
x 177
x 217
Ömür Tokman wrote: Tue Oct 03, 2023 7:56 am Thank you very much for the feedback. It's nice to be useful to someone, the qr code link is nice.
Thank you for creating this tool.
Might flood the SWYM'p with this code. :D
mme
x 10
Unread post by mme »
A very well done job. Thanks
x 2189
x 1890
I get this error when I run it:
Frank_Oostendorp
x 177
x 217
AlexLachance wrote: Wed Oct 04, 2023 9:39 am I get this error when I run it:
Had the same error. You have to de-select the missing reference, see my post above.
x 2189
x 1890
Frank_Oostendorp wrote: Wed Oct 04, 2023 10:05 am Had the same error. You have to de-select the missing reference, see my post above.
Thanks Frank, didn't think it was the same error.
After clearing it, it works like a charm. Here's the macro with the missing reference removed for those who don't know how to remove it.
QrCodeInsert.swp
(470 KiB) Downloaded 118 times
Ömür Tokman
x 972
x 328
Yes, I added that reference without removing it. Good thing you removed the reference and added it, I forgot to add it again.
Thanks Alex
Monstrum Mathias
Unread post by Monstrum Mathias »
Many thanks Ömür. This is a really useful code.
I use it for displaying dropbox-links for pdf and edrawings on the SolidWorks drawings.
When it inserts the picture it varies a great deal in size. Is there an easy way to adjust this size to a fixed value within the code?
What would be truly awesome is if the code was able to get the dropbox path of the pdf with the same name as the drawing and then paste that into the window. Is that at all possible within a macro in SW or is that wanting too much?
Answers: 24
x 752
x 907
AlexLachance wrote: Wed Oct 04, 2023 11:05 am Thanks Frank, didn't think it was the same error.
I get the following error whenever I run the modified version shared by Alex:
This happens after I type something in the box and select "generate QR Code"
I am using SW 2022 SP4 on Windows 10
Answers: 13
x 2041
x 1703
In the VBA editor, go to 'Tools-> References'. There is probably a broken reference that either needs to be unchecked, or more likely pointed to the correct dll.
This link has a more thorough explanation.
https://kb.blackbaud.com/knowledgebase/Article/75344
x 2189
x 1890
DanPihlaja wrote: Thu Apr 18, 2024 11:22 am I get the following error whenever I run the modified version shared by Alex:
Hey Dan,
Here's how to solve the issue:
Edit the macro and go in Tools>References
Uncheck the missing references and check the ones refering to 2022
Answers: 24
x 752
x 907
AlexLachance wrote: Thu Apr 18, 2024 11:29 am Hey Dan,
Thank you. I couldn't figure out how people got to the references window.
I looked at the help file and the only thing it said was "show the references window" I was like, "HOW!!?"
lol
