I'm currently working on a drawing pack that can be used by other engineers to get new products to production quicker. Basically, it's a set of generalised models/drawings that have global variables that the user can change to quickly output new drawings. The way it’s currently set up is you must go into each part and modify the driving equation. As you can imagine this isn't ideal. I've been researching a way to have it all driven from the assembly downwards. I've run into a couple issues.
1. If you have each sketch in every part undefined, and then edit the sketches in assembly to add relations to the primary component (in my case a rolled circular aluminium profile). When you copy tree, it loses this relation and it must be redone, which nullifies the effectiveness of this method.
2. If you tie the global variables to a text document, the link is lost again in copy tree. I haven't tested this fully I'm just going off other people's experiences. Let me know if I'm mistaken.
Essentially, I just want to create a model that requires the least amount of work possible to get it ready for production. I'm not too worried about the drawing as the custom properties/scale will need adjusting each time so that unavoidable.
If anyone has worked on something similar it would be great to hear your thoughts - Cheers
