Long time since my last posts!
Can I assign custom properties to individual weldment profiles?
For instance, we have some extrusion profiles and I plan to create some custom wedment profiles for them. I'd like to indicate maximum lengths for the different extrusions, but don't know if I can add that info to the weldment files.
SW 2022
Thanx
Weldment Custom Properties?
You can add custom properties to your .sldlfp files, and when those profiles are used in a Part the custom properties will carry over to the Part as cut list properties. Does that help?
Go to full post- Glenn Schroeder
- x 1636
- x 2045
Re: Weldment Custom Properties?
Great! That works.Glenn Schroeder wrote: ↑Mon Apr 29, 2024 9:06 am You can add custom properties to your .sldlfp files, and when those profiles are used in a Part the custom properties will carry over to the Part as cut list properties. Does that help?
Thanks Glenn
