Hello
Could you please explain how to simply draw juste the hole?
Are there any tools in SolidWorks to achieve this, or perhaps a mathematical formula I could use?
It involves two parallel segments representing two chords. I'm afraid my approach might be too simplistic, so I'm seeking expert advice.
Best regards.
How draw this hole ?
Re: How draw this hole ?
I can't think of a specific tool to create this directly.
I would draw a 10mm circle sketch; two parallel lines (chords) 8.5mm apart; then trim away the unwanted portions. The parallel lines need to be symmetrical about the diameter.
- x 2185
- x 1886
Maybe I'm not understanding your question correctly but what's so complicated about that...? Can you show your attempts..? Perhaps that would give us a better idea of the complexity you are facing.Aekzof wrote: ↑Sat May 04, 2024 1:53 am Hello
Best regards.
- x 1547
- x 1395
Circle with 2 flats.
https://www.mcmaster.com/products/rotar ... -shafts-5/
Circle with 2 flats like Fredrick said above, I would make the lines equal so they stay centered
- x 5
- x 53
Elementary, my dear Watson...
