Hello,
After a drawing note has been inserted, it is possible to change the leader option to "Attach Leader Center". Does anyone know if this can be changed somewhere in the document properties? I would like to make it the default in our drawing templets.
Attach Leader Center as Default
- x 6
- x 2
Re: Attach Leader Center as Default
It cannot. There is an SPR:Does anyone know if this can be changed somewhere in the document properties?
SPR # 1023142
Product SolidWorks
Status Open
Fixed in none none
Area Drawings
Sub-Area Annotations - Drawings
Customer Impact Medium
Add the ability to have 'Attach Leader' options for multi-line notes set to a default selection in document properties
- x 748
- x 907
I don't understand why, but there are tons of things that you cannot set a default for in Solidworks.
Many things can be set by modifying it and then saving a new template. But I am not sure if that is one of the things because it is a pain in the neck to do.
- x 1137
- x 1940
Some of these can be set under Options/Document Properties/Note but not this one.dpihlaja wrote: ↑Wed Dec 01, 2021 9:35 am I don't understand why, but there are tons of things that you cannot set a default for in Solidworks.
