How to make assembly manuals / instructions
How do you guys create assembly manuals?
We need to deliver printable instructions for in-house assembly, as well maintenance manuals with illustrations of how to disassemble and replace certain parts to the customer. For subassemblies with <10 parts we can usually get away with a simple exploded view. But for larger assemblies, we need to communicate which order the parts go together (building steps), detail views for where things are mounted and in what orientation, as well as list tools, lubricants, torques, and misc. assembly notes.
What we currently do for each main assembly is create an exploded view and multiple view states for each building step, which typically results in a drawing with 10-20 sheets. This can be quite slow to work with and the output doesn't look that great. Since we use Solidworks I have been trying out Composer, and I like to toon look can get there and the ability to export SVGs for inserting into Word documents. Is anyone here using Composer or other specialized software for this type of work?
- Jaylin Hochstetler
- x 379
- x 355
Re: How to make assembly manuals / instructions
We looked into Composer, but I think it's overpriced for not more than it can do. It's a screenshot program on steriods. Especially if you compare it to SolidEdge Technical Publications. SE Tech Pub is cheaper plus it is quite a bit more capable. Unlike Composer you can do everything in Tech Pub you don't have to export Vector images like you do in Composer.
Currently we use a combination of Word and Assembly Drawings with exploded views. Sometimes I'll make a assembly drawing with labels on each drawing view and then reference the drawing view names in the Word step by step document. Or we'll put the step by step instructions in the Assembly drawing, I attached an illustration. This drawing was done in SE. (FYI, we went from SW to SE) We eventually plan to get Tech Pubs.
Rainshade Installation_REV00.pdf
- (398.88 KiB) Downloaded 222 times
- x 441
- x 235
We looked into composer too but it's incredibly expensive (you also need to train people to use it properly which is an underestimated additional cost). For our in house production we mostly use standard operating procedures that are put together not by the design department. They use photos & text (MS publisher - I would use something else though) and work with screenshots from the model or photos from the actual assembly. Very rarely we need to make an exploded view for them where they draw in some notes.martin wrote: ↑Tue Aug 02, 2022 8:58 am How do you guys create assembly manuals?
We do not use videos. Videos are great if you do it for the first time - but afterwards you don't want to spend the time looking through a video to find a specific assembly step.
I cannot post something more detailed due to policy reasons - but maybe this helps:
If your company policy allowed, maybe CADASIO might worth a try?
1 year ago they are looking for feedback
https://www.cadforum.net/viewtopic.php?t=813
- x 1554
- x 1404
Exploded view.
Do it so you can show assemble and disassemble steps.
Organize model into subassemblies that follow assemble steps.
Is there an easy way to show multiple steps of an assembly in a drawing? At least without creating a unique exploded view for each drawing view?
For example, my exploded assembly has 3 steps. I would like to create a drawing view with only step 1 active, then a 2nd view with both step 1 and 2 active, and then a final view with all 3 steps applied. Is this possible?
Does anyone work for Lego instructions department? Whatever Lego uses to make their books, that's what we need in our MES/Routings.
But it needs to show up in where used searches or automatically update when parts/assemblies are revised so instructions are correctly maintained with the CAD data.
- x 1554
- x 1404
- x 1138
- x 1945
No, you need to create a separate exploded view for each step.SPerman wrote: ↑Wed Aug 03, 2022 8:30 am Is there an easy way to show multiple steps of an assembly in a drawing? At least without creating a unique exploded view for each drawing view?
Here I created 3 exploded views. I also created 3 unlinked Display States since I don't want to see all components. Set the view for the Exploded you want, and the Display State. Repeat for other views
I was afraid that was the answer. It looks like one could create the full explosion, and then copy it and drop off 1 step each time. At least that way you aren't doing the same work over and over.
- x 1138
- x 1945
In this case there are 3 explodes, but none of them are full explosions, just what you see in the view. I see your point though, the ability to control the exploded sub "Steps" at the drawing level would be useful.
