Solid Edge 2019 Customized Keystrokes
Tig
Unread post by Tig »
When sketching in solidedge 2019 draft is there a way to add customized keystrokes without a modifier. For instance, I would like to be able to type "L" for line not "ctrl L". I've used Autocad for 20+ years and I'm used to hitting various keys for various commands. Now with a new job using SolidEdge I find when I'm sketching in a draft file I'm continually hitting keys that do nothing. (Muscle memory). I was hoping to get my customized keys back in SE.
x 1168
x 2304
Re: Solid Edge 2019 Customized Keystrokes
As far as I know, L is part of the built in toggle to move between Arc and Line. You can use an F key as a single stroke hotkey, as far as I can tell.
KennyG
x 43
x 184
Unread post by KennyG »
Another option is to use the Radial menu which has the Line command on the right inner section in all environments where Line is supported, and since it is on the inner section it also available with the "gesture" action.
