macro help needed
Library for macros
BarryH
macro help needed
Unread post by BarryH »
Hi all, I am new to this forum and have no programming experience. I have recorded a macro which takes a preselected flat face and offsets the perimeter by a set distance inwards. (I use it frequently for locating screw holes). It works perfectly every time. I then select that sketch, right click and change the colour to red. It would be great if I could integrate the colour change into the macro. I have tried recording it but the colour does not change. Can anybody help?
by JSculley » Wed Nov 09, 2022 1:49 pm
Option Explicit
Dim mDoc As ModelDoc2
Dim selMgr As SelectionMgr
Dim sketchMgr As SketchManager
Dim theSketch As Sketch
Dim theSketchFeature As Feature
Dim selCount As Long
Dim selType As swSelectType_e
Dim selFace As Face2
Dim i As Integer
Dim result As Boolean
    Set mDoc = swApp.ActiveDoc
    Set selMgr = mDoc.SelectionManager
    selCount = selMgr.GetSelectedObjectCount2(-1)
    If selCount <> 1 Then 'Too many things selected, notify user and exit
        swApp.SendMsgToUser2 "Please select a single planar face", swMessageBoxIcon_e.swMbStop, swMessageBoxBtn_e.swMbOk
        Exit Sub
    selType = selMgr.GetSelectedObjectType3(1, -1)
    If Not selType = swSelFACES Then 'Selection is not a face, notify user and exit
        Exit Sub
    Set selFace = selMgr.GetSelectedObject6(1, -1)
    Dim norm As Variant
    norm = selFace.Normal
    If norm(0) = 0 And norm(2) = 0 And norm(1) = 0 Then 'Face is not planar, notify user and exit
        swApp.SendMsgToUser2 "Selected face is not planar", swMessageBoxIcon_e.swMbStop, swMessageBoxBtn_e.swMbOk
        Exit Sub
    Set sketchMgr = mDoc.SketchManager
    sketchMgr.InsertSketch False 'Start sketch on face
    Set theSketch = sketchMgr.activeSketch
    result = mDoc.SketchOffsetEntities2(-0.25 * 25.4 / 1000, False, False)  'Offset face 0.25" inward
    sketchMgr.InsertSketch True 'Exit sketch
    Set theSketchFeature = selMgr.GetSelectedObject6(1, -1) 'Get feature for the sketch which is selected
    Dim props As Variant
    props = theSketchFeature.GetMaterialPropertyValues2(1, Nothing) 'Get the current properties
    props(0) = 1 'Set the RED value
    props(1) = 0 'Set the GREEN value
    props(2) = 0 'Set the BLUE value
    theSketchFeature.SetMaterialPropertyValues2 props, 1, Nothing 'Set the properties
Jordan Brown
x 6
Re: macro help needed
Unread post by Jordan Brown »
I cannot find an accessor for the sketch colour in the sketch interface. Unless it is hidden somewhere obscure, I do not think that it can be changed using the API.
Storm
Answers: 13
x 2064
x 1724
x 8
x 830
Option Explicit
Dim i As Integer
        Exit Sub
        Exit Sub
    Dim norm As Variant
        Exit Sub
BarryH
Thank you very much JSculley, That works perfectly!
