Adding Images
Make suggestion to the moderators and admins of this site.
Answers: 13
x 2041
x 1703
Adding Images
Matt,
This is probably beyond your control, but thought I would bring it up just in case.
When adding images to a post, it is a little confusing.
From what I can tell, the first image added is image 0. If you add a 2nd image, it now becomes image 0 and the original image 0 is changed to image 1.
That wouldn't be too bad, but there is no thing in the list of images to tell you which is which. Sometimes I want to replace a screenshot with a different image, and it is a bit confusing with the current layout.
Not a big deal, but I wanted to mention it.
x 7
x 822
Re: Adding Images
You can use the 'File Comment' field to help remember which is which. The comment shows up below the image in the post as well.
Radius
Radius
Signatures
Signatures
Rev block
Rev block
