Not sure, but it looks like they've combined the Extrude and Boolean Common features into one op. So to answer your question, yes that can be done in nearly every other CAD system, it will just take extra steps. IMO Inventor extrude and revolve features UI options have been ahead of the other parametric modelers for years. I don't know when it started but IIRC Inventor didn't care what type of extrude it was, they all had the same feature and could be edited later. Surface, solid, thin, cut, add; didn't matter all the same feature. That was very nice. I'm not surprised to see they took the next step and added Boolean operations right into the feature options now.
You can do the exact same thing in Solid Edge using the Extrude command with the Cut option and setting the cut side to the outside (defaults to inside for a closed sketch).
