BOM sort (sort on insert)
Bryan O
x 12
x 15
Unread post by Bryan O »
I've created a custom BOM which (on insert) sorts automatically by assembly build order.
I know I can manually sort after the fact but can I get my custom BOM to sort alphabetically by part number(header) on insert?
by JSculley » Tue Dec 12, 2023 3:41 pm
I don't think you can. You can save the sort settings to the template, but you must manually apply the saved settings in new documents that use the template. See:
https://help.solidworks.com/2024/Englis ... etting.htm
x 388
x 417
Re: BOM sort (sort on insert)
After doing the desired sort, save the BOM template. And then next time it should sort on sort, you can right click on the BOM and select sort > apply sort (check reply by @JSculley below)
Answers: 13
x 2064
x 1724
That does not work for me. (2022 SP5)
x 8
x 830
x 388
x 417
JSculley wrote: Tue Dec 12, 2023 3:41 pm I don't think you can. You can save the sort settings to the template, but you must manually apply the saved settings in new documents that use the template. See:
Yes that is correct once I rechecked. But it wa working for me earlier and hence I did not add the extra step.
x 388
x 417
The API person inside me is thinking of a macro using which you insert the BOM and it get sorted as needed.
Bryan O
x 12
x 15
Thanks @gupta9665 &@JSculley . Works like I want it to now!
