Macro for Renaming all Sketches
I've been looking for a macro to rename all sketches in feature tree to the name of the feature it belongs to + Sketch.
Something like :
Does anyone know a macro that does something like this?
thanks.
Something like :
thanks.
Here is a quick (dirty) macro that does the job.
Go to full postCode: Select all
Sub Mian()
Dim swPart As SldWorks.PartDoc
Dim swSubFeature As SldWorks.Feature
Dim FeatureName As String
Dim i As Integer
Set swPart = swApp.ActiveDoc
Set swFeat = swPart.FirstFeature
While Not swFeat Is Nothing
If swFeat.GetTypeName2 <> "ProfileFeature" Then
Set swSubFeature = swFeat.GetFirstSubFeature
While Not swSubFeature Is Nothing
If swSubFeature.GetTypeName2 = "ProfileFeature" Then
FeatureName = swFeat.Name & " Sketch"
While False <> swPart.FeatureManager.IsNameUsed(swNameType_e.swFeatureName, FeatureName)
i = i + 1
FeatureName = swFeat.Name & " Sketch" & (i)
Wend
swSubFeature.Name = FeatureName
Set swSubFeature = swSubFeature.GetNextSubFeature
Wend
Wend
Re: Macro for Renaming all Sketches
There is a macro to hide all sketches in a model but I have not seen a one to rename them based on their feature name. This one will have to be made.
How would it work when sketches are shared?
We never use shared Sketches.
But for the sake of changes in our workflow in future, I prefer it be named with the first feature that use that sketch.
If it makes any problem, renaming it to the last feature is OK as well.
thanks.
Now that it seems what I need is not possible,
is it possible to rename only the selected sketch to --> the name of the feature it belongs to + SK?
thanks again.
thanks again.
Sub Mian()
Dim i As Integer
i = i + 1
Wend
Wend
Wend
- x 2185
- x 1886
gupta9665 wrote: ↑Wed Feb 14, 2024 2:46 am Here is a quick (dirty) macro that does the jib.
Sub Mian() Dim swApp As SldWorks.SldWorks Dim swPart As SldWorks.PartDoc Dim swFeat As SldWorks.Feature Dim swSubFeature As SldWorks.Feature Dim FeatureName As String Dim i As Integer Set swApp = Application.SldWorks Set swPart = swApp.ActiveDoc Set swFeat = swPart.FirstFeature While Not swFeat Is Nothing If swFeat.GetTypeName2 <> "ProfileFeature" Then Set swSubFeature = swFeat.GetFirstSubFeature While Not swSubFeature Is Nothing If swSubFeature.GetTypeName2 = "ProfileFeature" Then FeatureName = swFeat.Name & " Sketch" While False <> swPart.FeatureManager.IsNameUsed(swNameType_e.swFeatureName, FeatureName) i = i + 1 FeatureName = swFeat.Name & " Sketch" & (i) Wend swSubFeature.Name = FeatureName End If Set swSubFeature = swSubFeature.GetNextSubFeature Wend End If Set swFeat = swFeat.GetNextFeature Wend End Sub
Deepak still beeing the man
Thanks to both.
Will give it a try.
Will give it a try.
@gupta9665 Million thanks.gupta9665 wrote: ↑Wed Feb 14, 2024 2:46 am Here is a quick (dirty) macro that does the job.
Works perfect.
I only had to add a If Left(swSubFeature.Name, 6) = "Sketch" Then to prevent renaming the sketches that have already been renamed manually, and add a i = 0 after GetNextFeature to reset the counter for each feature.
I really don't know how to appreciate this favor.
Thanks again.
