Transform multipy a point to get measurements in reference coordinate system
Posted: Wed Apr 10, 2024 11:14 am
Hello!
I am having issues transforming the XYZ assembly coordinates of a point to be relative to a reference coordinate system in the assembly. Users of this macro will build their assemblies in any orientation, however, the reference coordinate system will always be oriented the same way so it would be helpful for further calculations to translate the points.
I have already calculated the Transform Matrix for the reference coordinate system, and found the XYZ coordinates of the points I need to convert, but when I try and use the .MultiplyTransform function, the new values it gives for the points are not correct.
The reference coordinate system “MTV” is located at the point “FrontRight”, so the new XYZ values should be 0, 0, 0. Instead I am getting 0.05715, 0.62865, 24.867602.
Image of the Origin Coordinate System and the MTV Coordinate System:
![Image](%5Battachment=0%5DScreenshot%202024-04-10%20071259.jpg%5B/attachment%5D)
VBA Code:
Results Window:
Any help would be appreciated! Thank you in advance!
VBA Code:
Option Explicit
Sub main()
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim status As Boolean
Dim myPoints As Variant
Dim point As Variant
Dim pointFeature As Variant
Dim swMathPt As SldWorks.MathPoint
Dim swAssy As SldWorks.AssemblyDoc
Set swModel = swApp.ActiveDoc
Dim FrontRight As Variant
Dim RearRight As Variant
Dim FrontLeft As Variant
Dim PushHeight As Variant
Dim MTVCoords As Variant
Dim PointArray As Variant
FrontRight = Array(0, 0, 0)
RearRight = Array(0, 0, 0)
FrontLeft = Array(0, 0, 0)
PushHeight = Array(0, 0, 0)
MTVCoords = Array(1, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0)
PointArray = Array(FrontRight, RearRight, FrontLeft, PushHeight, MTVCoords)
Dim MomentofInertiaLyy As Long
Dim MomentofInertiaLxx As Long
MomentofInertiaLyy = 0
MomentofInertiaLxx = 0
Dim CartMassCG As Variant
Dim LoadMassCG As Variant
CartMassCG = Array(0, 0, 0, 0)
LoadMassCG = Array(0, 0, 0, 0)
Dim i As Integer
Dim j As Integer
Dim CartLengthValue As Long
Dim CartWidthValue As Long
Dim PushHeightValue As Long
Dim selByIdStr As String
Dim boolstatus As Boolean
Dim swComp As SldWorks.Component2
Dim swMathUtils As SldWorks.MathUtility
Dim coordSysFeature As Variant
'FIND MTV COORDINATE TRANSLATION----------------
'https://www.codestack.net/solidworks-api/geometry/transformation/get-coordinate-system-transform/
boolstatus = swApp.ActiveDoc.Extension.SelectByID2("MTV", "COORDSYS", 0, 0, 0, False, 0, Nothing, 0)
Set swFeat = swSelMgr.GetSelectedObject6(1, -1)
'Get the Transform Matrix of the Coordiante System
If Not swFeat Is Nothing Then
Dim swCoordSys As SldWorks.CoordinateSystemFeatureData
Set swCoordSys = swFeat.GetDefinition
Dim swMathTransform As SldWorks.MathTransform
Set swMathTransform = swCoordSys.Transform
Dim vMatrix As Variant
vMatrix = swMathTransform.ArrayData
i = 0
For i = 0 To 15
MTVCoords(i) = vMatrix(i)
Next i
End If
Debug.Print "MTV Coordiante System Transform Matrix:"
Debug.Print vbTab & MTVCoords(0) & ", " & MTVCoords(1) & ", " & MTVCoords(2) & ", " & MTVCoords(13)
Debug.Print vbTab & MTVCoords(3) & ", " & MTVCoords(4) & ", " & MTVCoords(5) & ", " & MTVCoords(14)
Debug.Print vbTab & MTVCoords(6) & ", " & MTVCoords(7) & ", " & MTVCoords(8) & ", " & MTVCoords(15)
Debug.Print vbTab & MTVCoords(9) & ", " & MTVCoords(10) & ", " & MTVCoords(11) & ", " & MTVCoords(12)
'GET POINT COORDINATES--------------------------
myPoints = Array("FrontRight", "RearRight", "FrontLeft", "PushHeight")
i = 0
For Each point In myPoints
status = swModelDocExt.SelectByID2(point & "@" & swModel.GetTitle, "DATUMPOINT", 0, 0, 0, False, 1, Nothing, 0)
Set pointFeature = swFeat.GetSpecificFeature2
Debug.Print point & " Coordinates:"
If Not pointFeature Is Nothing Then
Set swMathPt = pointFeature.GetRefPoint
Debug.Print vbTab & "x: " & swMathPt.ArrayData(0) * 1000# / 25.4 & "in"
Debug.Print vbTab & "y: " & swMathPt.ArrayData(1) * 1000# / 25.4 & "in"
Debug.Print vbTab & "z: " & swMathPt.ArrayData(2) * 1000# / 25.4 & "in"
j = 0
For j = 0 To 2
PointArray(i)(j) = swMathPt.ArrayData(j) * 1000# / 25.4
Next j
Else
MsgBox "Point not found"
End If
i = i + 1
Next point
'THEN TRANSFORM COORDIANTES TO MTV--------------
Set swMathUtils = swApp.GetMathUtility
i = 0
For Each point In PointArray
Set swMathPt = swMathUtils.CreatePoint(point)
Set swMathTransform = swMathTransform.Inverse
Set swMathPt = swMathPt.MultiplyTransform(swMathTransform)
Dim vCompMTVPoint As Variant
vCompMTVPoint = swMathPt.ArrayData
j = 0
For j = 0 To 2
Next j
Debug.Print myPoints(i) & ": "
Debug.Print vbTab & Join(PointArray(i), ", ")
i = i + 1
Next point
'THEN CALCULATE LENGTHS-------------------------
CartLengthValue = 0
CartWidthValue = 0
PushHeightValue = 0
'THEN Next Step---------------------------------
3.56327999173599E-17, 1.55218636003651E-18, -1, 0
-1, 1.18775999724533E-17, -3.56327999173599E-17, 0
1.18775999724533E-17, 1, 1.55218636003651E-18, 0
0.62865, -0.117601999999998, 0.05715, 1
FrontRight Coordinates:
x: 24.75in
y: -4.62999999999994in
z: 2.25in
RearRight Coordinates:
x: 22.75in
z: 39.75in
FrontLeft Coordinates:
x: 1.25in
z: 2.25in
PushHeight Coordinates:
x: 11.9973570414032in
y: 31.38439107887in
z: 47.6945927106677in
FrontRight:
RearRight:
-22.12135, -0.117601999999998, 5.71499999999992E-02
FrontLeft:
0.05715, 0.62865, 1.367602
PushHeight:
-11.3687070414032, -0.117601999999998, 5.71499999999995E-02
