Whenever I open a new part created by others, it comes in with a scene/environment/background enabled. Is there any way to make these go away always and forever or am I stuck with deleting this garbage on every part? Again, I'm asking about parts created by others, not my own.
Thanks in advance for your suggestions.
Can I get rid of all Scenes?
- x 27
- x 90
There's a System setting:
Go to full postRe: Can I get rid of all Scenes?
I've run into this before and wondered, why is the desirable behavior different than the "recommended" option. What makes Use Document setting the recommended?
I've been taught that most of the time when a software company says one option is "recommended" over others, their best intentions are not aligned with mine, or most users.
- x 2189
- x 1890
Recommended pretty much means if you switch this setting issues might arise and you will have to deal with them. And by issues, I mean user issues, not necessarily program issues.
- x 27
- x 90
- x 752
- x 907
My assumption is that using the document setting is recommended in case you run into a situation where someone has changed the color of a portion of the part and it may blend into your personal settings. The assumption is that, if a portion is hard to see because of blending into the background, that the user wold have changed the background to see it better.AlexLachance wrote: ↑Thu Apr 25, 2024 12:00 pm Recommended pretty much means if you switch this setting issues might arise and you will have to deal with them. And by issues, I mean user issues, not necessarily program issues.
Therefore, it is recommended because 80% of users (a number that is NOT represented by the population of this forum) probably don't know how to change the background color on an as needed basis to fix the problem.
