How draw this hole ?
Aekzof
Unread post by Aekzof »
Hello
Could you please explain how to simply draw juste the hole?
Are there any tools in SolidWorks to achieve this, or perhaps a mathematical formula I could use?
It involves two parallel segments representing two chords. I'm afraid my approach might be too simplistic, so I'm seeking expert advice.
Best regards.
Slasher
x 14
Re: How draw this hole ?
Unread post by Slasher »
I can't think of a specific tool to create this directly.
I would draw a 10mm circle sketch; two parallel lines (chords) 8.5mm apart; then trim away the unwanted portions. The parallel lines need to be symmetrical about the diameter.
x 2171
x 1859
Aekzof wrote: Sat May 04, 2024 1:53 am Hello
Best regards.
Maybe I'm not understanding your question correctly but what's so complicated about that...? Can you show your attempts..? Perhaps that would give us a better idea of the complexity you are facing.
x 1538
x 1382
TTevolve
x 78
x 143
Unread post by TTevolve »
Circle with 2 flats like Fredrick said above, I would make the lines equal so they stay centered
IndianaDave
x 4
x 53
Unread post by IndianaDave »
Elementary, my dear Watson...
