This is a test for a new standard theme
Posted: Wed Mar 17, 2021 2:14 pm
by matt
I have changed the default style for guests to Prolight. I'm thinking of using this as the basis for a new custom style for us. To see this theme, either set your own theme in the user control panel to Prolight or sign out, then sign back in and your personal selected theme will return.
Plus, if you look up in the upper right corner, there's a moon shape, which lets you take it dark. I'm going to test this theme and see how it goes. So far, I like it. If you want to send me some images of models you've worked on to put together into a header, that would be a help. Otherwise I'll use my own models.
Re: This is a test for a new standard theme
Posted: Wed Mar 17, 2021 7:25 pm
by zwei
Hmm...
Not sure i am doing it wrong or what...
I had changed my theme to Prolight but it seem to be different from what i see when i viewing as guest
My view:
Guest view:
Posted: Thu Mar 18, 2021 7:43 am
by Jaylin Hochstetler
Zhen-Wei Tee wrote: ↑Wed Mar 17, 2021 7:25 pm
Hmm...
My view:
Guest view:
I noticed the same thing. Though I do like the Prolight theme. It looks a little bit more modern and professional.
Posted: Thu Mar 18, 2021 8:48 am
by mattpeneguy
Nice work @matt! I really like this new Dark theme. I just noticed it in the upper right corner.
Posted: Thu Mar 18, 2021 8:54 am
by matt
mattpeneguy wrote: ↑Thu Mar 18, 2021 8:48 am
The cool thing is that it just inverts all css colors, so it can be used with any theme. If you use it with a dark theme, it turns light. Use it with Carbon, and it comes out a gray tone. I think it helps make more people happy with a limited number of themes.
I'm going to cut back some of the crazier color schemes I think.
Posted: Thu Mar 18, 2021 8:58 am
The dark version is way too dark, the borders need to stand out more and the background needs to be a shader lighter then the post backgrounds or vice versa.
Posted: Thu Mar 18, 2021 9:34 am
AlexLachance wrote: ↑Thu Mar 18, 2021 8:58 am
I agree on that one.
Posted: Thu Mar 18, 2021 10:06 am
by mattpeneguy
Jaylin Hochstetler wrote: ↑Thu Mar 18, 2021 9:34 am
[sarc]I suppose you complained about the icon color change that SW made a few years back, too.[/sarc] Only thing, I don't like is the blue banner at the top. But, I'm pretty sure I can change that.
Have you guys tried tweaking the colors before changing it to Dark?
Edit to Add: Guys just changing to Carbon gives you this:
So, I'm sure you'll find something that works. Keep in mind you couldn't do any of this on the old forum, to my knowledge...
Posted: Thu Mar 18, 2021 10:22 am
by matt
Really, take a look here, go shopping, and I'll add some new stuff. Writing something new isn't really an option, we don't have a revenue stream (yet). Unless someone is gonna volunteer, so we have to pick from available stuff.
https://www.phpbb.com/customise/db/styl ... 80f5d7c163
Posted: Thu Mar 18, 2021 11:05 am
by zwei
My personal favorite is this theme... but i cant seem to get it now?
Posted: Thu Mar 18, 2021 11:21 am
by matt
Flat Style Blue is still there
Posted: Thu Mar 18, 2021 12:27 pm
mattpeneguy wrote: ↑Thu Mar 18, 2021 10:06 am
Not trying to complain. This is a great forum.
I switched to the Carbon theme and really like it so far.
Posted: Thu Mar 18, 2021 12:57 pm
by MJuric
matt wrote: ↑Wed Mar 17, 2021 2:14 pm
Not really a fan of the Prolight...I'm getting old and the text seems smaller and harder to read. I've use the flat blue and just switched to the Carbon and like both more than the Prolight.
Posted: Thu Mar 18, 2021 2:44 pm
by berg_lauritz
Hmm...
My view:
Guest view:
Same here - the guest view is horrible for whatever reason.
Posted: Thu Mar 18, 2021 6:18 pm
by zwei
matt wrote: ↑Thu Mar 18, 2021 11:21 am
Thanks! How can i missed that
Posted: Thu Mar 18, 2021 6:25 pm
by zwei
MJuric wrote: ↑Thu Mar 18, 2021 12:57 pm
I agree with this.
Prolight seem to be too bright imo.
Flat blue work pretty well for me
Posted: Fri Mar 19, 2021 9:57 am
by zwei
So it seem that the guest theme was reverted to Flat Blue... Thanks for that
Posted: Fri Mar 19, 2021 10:04 am
I've switched to Flat Gold and went for the dark version, it fits my taste, except the whitish banner that's a little too bright, everything else stands out as I like it!
Posted: Fri Mar 19, 2021 10:23 am
by matt
I'd be interested in what you all think of the changes to Supernova theme, light and dark.
Posted: Fri Mar 19, 2021 10:40 am
matt wrote: ↑Fri Mar 19, 2021 10:23 am
Hey Matt,
I'm on it right now, the light mode's looking really good with these ''soft colors'', they mesh in really well, specially with the logo of the company I work for
Dark mode's not too bad either, but I think the banner's a little too contrasting on the rest. I actually prefer the light mode on Supernova.
Posted: Sat Mar 27, 2021 3:35 am
by zwei
Hmm... not sure what happened... did the guest theme changed again?
Posted: Tue Mar 30, 2021 10:07 am
by Jim Steinmeyer
I suppose you complained about the icon color change that SW made a few years back, too. Only thing, I don't like is the blue banner at the top. But, I'm pretty sure I can change that.
[/quote]
What about the "New Forum"? Bet we could do it there.
Posted: Tue Mar 30, 2021 11:19 am
by Tony Tieuli
I've gotta go along with Alex. I like the light, the dark... not so much.
Posted: Wed Mar 31, 2021 2:09 pm
The blue text on the dark grey background is terrible.
- image.png (9.46 KiB) Viewed 1904 times
Posted: Fri Apr 02, 2021 10:18 am
by Merovingien
that's one of the reasons i use : Flat Style Gold
