Number of instances hole callout for patterned hole wizard
- x 441
- x 235
Is it possible to have SolidWorks show on a drawing through the hole callout the number of instances from a hole wizard hole, that is patterned through a sketch pattern?
I'm on SolidWorks 2017 SP5
If not mistaken, I believe the <NUM_INST> will not work for sketch driven pattern as the software could not count the points in it (unlike linear pattern etc) There is several similar discussion in the old forum (which i had lost my bookmark
) and seem to be a pretty common issue with ssp n SOLIDWORKS
A lot of time i just end up count it manually if the hole callout is not working
And if the number of hole is too many, there is a macro that export the number of hole based on size (by artem if not mistaken)
Go to full post![Sad :(](./images/smilies/icon_e_sad.gif)
- x 1232
Re: Number of instances hole callout for patterned hole wizard
Why don't you get rid of your sketch pattern and use Hole Wizard for its intended purpose? HW is really a library feature and sketch pattern put together. Using a sketch pattern for a HW feature is redundundundant.
Also, allow me to say that Solid Edge has a brilliant solution for the callout problem:
- x 1659
- x 2060
As @mike miller indicated, you're doing things backward. Move your sketch pattern up above the hole wizard feature, then drop your hole wizard points coincident with the points of the sketch. I pretty much always use a stand-alone sketch to drive my hole wizard features. My hole wizard sketches only consist of the points, with no dimensions, construction lines, etc.
- x 441
- x 235
@mike miller, @Glenn Schroeder I have a SSP, that has a sketch with the hole locations. How do I properly populate this into the hole wizard? It does not allow me to use the sketch from the SSP for the hole wizard.
And if I need to manually place the points onto the sketch from the SSP, I lose the benefits of the SSP having the sketch. This is the same, if I derive the points from the SSP into the hole wizard sketch.
That solution really is brilliant.Also, allow me to say that Solid Edge has a brilliant solution for the callout problem:
- x 1659
- x 2060
I've never used an SSP, but you can't have the SSP sketch visible, then drop the Hole Wizard points coincident with points, end points, center points, etc on the SSP sketch? If not, make a new sketch in your Part, referencing the SSP sketch (probably using Convert Entities), then drop your Hole Wizard points coincident with features in it.berg_lauritz wrote: ↑Tue Jul 20, 2021 11:29 am @mike miller, @Glenn Schroeder I have a SSP, that has a sketch with the hole locations. How do I properly populate this into the hole wizard? It does not allow me to use the sketch from the SSP for the hole wizard.
- x 27
- x 90
Have you tried a hole note? It works for me.
- x 441
- x 235
That is exactly what I am trying to avoid. I will loose all the benefits of the SSP like that:Glenn Schroeder wrote: ↑Tue Jul 20, 2021 12:08 pm I've never used an SSP, but you can't have the SSP sketch visible, then drop the Hole Wizard points coincident with points, end points, center points, etc on the SSP sketch? If not, make a new sketch in your Part, referencing the SSP sketch (probably using Convert Entities), then drop your Hole Wizard points coincident with features in it.
- If I use convert entities, I will have to go back & add holes/remove them, if I add points to the SSP. Thus I loose the benefit of only editing the SSP to add/remove holes
- If I add them manually, I have the problem, that I have to click every single hole & add a point to it. Additionally the same problem from 1. persists!
It does not show the number of instances for me with the hole note, if I pattern the hole wizard feature. Which version are you on?
- x 27
- x 90
I'm on 2019.
If the hole note doesn't give you a count, try putting this in the Dimension Text box ahead of the hole dimension: <NUM_INST>X
- x 441
- x 235
just found it 5 minutes ago:
https://r1132100503382-eu1-3dswym.3dexp ... K95p7b9uxA
you were correct, @Zhen-Wei Tee , it was answered there before.
