Zebra Stripes
- Maha Nadarasa
- x 51
- x 48
Zebra Stripes
How to improve this Zebra Stripes? This is G1 relation between curve and surface. I tried with G2 and G3 relation but it did not work.
Extension Flap.SLDPRT
- (208.11 KiB) Downloaded 88 times
When you work with surfaces keep in mind to select edges so you can apply tangency in the connections - Loft, Boundary and Fill, If I am not mistaken.
So in this case the easiest way is the Boundary Surface:
Go to full postSo in this case the easiest way is the Boundary Surface:
Re: Zebra Stripes
Extension Flap - Boundary Lucas.SLDPRT
- (123.17 KiB) Downloaded 90 times
Re: Zebra Stripes
Also changing the arc to spline:
Extension Flap - Spline.SLDPRT
- (132.33 KiB) Downloaded 73 times
Re: Zebra Stripes
And increasing the degree of the spline you can start the spline curvature close to zero, making Curvature to Face possible. This is as far as I know for now .-.
Extension Flap - Spline Curvature.SLDPRT
- (150.98 KiB) Downloaded 81 times
- Maha Nadarasa
- x 51
- x 48
Re: Zebra Stripes
@Lucas
Thanks for the help.
