Fillet Issue
Maha Nadarasa
x 51
x 48
Fillet Issue
I tried to replicate this model. Fillet is placed to the edge of the model (time 8.30) but it is not coming to me. How to fix this?
Surface Modeling-Advanced Surface Modeling.SLDPRT
(851.88 KiB) Downloaded 77 times
by Lucas » Sun Sep 05, 2021 7:41 pm
Maha Nadarasa wrote: Sun Sep 05, 2021 8:37 am It is not coming for me
The file I sent is not creating fillet? I just checked here at work and got the same result.
I also get this error if I try to fillet with just one edge selected. Try using Box Selection on the whole part, SW will automatically recognize the edges.
Or with Show Selection Toolbar on, will appear that selection options:
Lucas
x 171
x 169
Re: Fillet Issue
Unread post by Lucas »
Fillet is fine, but I couldn't use thicken with 1.5mm on both directions. Just outwards is fine, tho.
Surface Modeling 2.SLDPRT
(2.81 MiB) Downloaded 107 times
Maha Nadarasa
x 51
x 48
Re: Fillet Issue
Lucas wrote: Sun Sep 05, 2021 8:07 am Fillet is fine, but I couldn't use thicken with 1.5mm on both directions. Just outwards is fine, tho.
Lucas
x 171
x 169
Re: Fillet Issue
Maha Nadarasa
x 51
x 48
Re: Fillet Issue
Lucas wrote: Sun Sep 05, 2021 7:41 pm The file I sent is not creating fillet? I just checked here at work and got the same result.
This was the issue I had selecting edge one by one will not work. Using Box Selection will work. Do you know the reason?
Lucas
x 171
x 169
Re: Fillet Issue
Trying to select them form the outside is difficult because of the curvature, but not a problem from the inside.
