Why does it come like this?
- Maha Nadarasa
- x 51
- x 48
This a continuation from "Solidworks Sequential Numbering" (https://www.cadforum.net/viewtopic.php? ... RRAY#p5723) changing the original file name (from Part2 to PA) and opening and closing the feature LPattern6, giving this results. Notice array of D. What is the reason?
- PA.SLDPRT
- (476.06 KiB) Downloaded 103 times
Re: Why does it come like this?
The original part was in inches and you are using a system in mm maybe?
Try to play with the units.
All the opinions are my own.
No idea and can't probably open your part, still on 2018.Maha Nadarasa wrote: ↑Mon Sep 27, 2021 5:36 pm This a continuation from "Solidworks Sequential Numbering" (https://www.cadforum.net/viewtopic.php? ... RRAY#p5723) changing the original file name (from Part2 to PA) and opening and closing the feature LPattern6, giving this results. Notice array of D. What is the reason?
What was in the text originally? When I was doing that I found a whole lot of weirdness so having it pull a random letter from somewhere would not surprise me.
- x 2489
- x 1899
You should be grateful...If SW worked reliably and didn't have bugs like this for you to sort out, then your employer could hire any lackey to do CAD work...Just think of this bug as job security....
Kidding aside...that's weird. If you open the Custom Properties and edit the sketch it "fixes" it. But, I wouldn't rely on this not breaking in the future. Can you send the file to your VAR? Fixing this should be trivial, but it'll require an SPR and some attention from the SW developers.
- Maha Nadarasa
- x 51
- x 48
I do not have 2018v but you can try this with your version. Only thing is, you have to do what I did.
-change the name of the file
-Just open and close the LPattern6
Fixing this should be trivial, but getting the SW developers attention certainly is not.mattpeneguy wrote: ↑Tue Sep 28, 2021 8:18 am Fixing this should be trivial, but it'll require an SPR and some attention from the SW developers.
If you have renamed the part from windows explorer instead of using "save as" inside SW, probably the pointers inside the part properties will still try to lookup at the old filename @part.sldprt instead of the new one @p2.sldprt . If you open and close the property window (the icon near the option "gear" on the top toolbar) it triggers the regeneration of sketch 7 and 8.
I think it could be "by design" because SW seems to store inside the file absolute path pointers (ie pointing at a certain filename in a certain place instead of a generic "current part") . I saw this kind of behaviour in some bugged parts that shown out of nowhere properties sort of linked to other parts...
That's pretty much what I tumbled too when I was working on it. There are few other combinations of actions that seem to force a rebuild, can't remember what they were, but most of those were not 100% and were more complex. Opening the file properties window and closing it seemed to work 100% of the time and was only one click.mp3-250 wrote: ↑Tue Sep 28, 2021 8:55 pm If you have renamed the part from windows explorer instead of using "save as" inside SW, probably the pointers inside the part properties will still try to lookup at the old filename @part.sldprt instead of the new one @p2.sldprt . If you open and close the property window (the icon near the option "gear" on the top toolbar) it triggers the regeneration of sketch 7 and 8.
Seems completely wrong that opening the file properties window would do something that a rebuild does not....but it is Solidworks
It isn't 'D'. It is:
The line to which the text is attached is short, so the text is truncated. The text is linked to the 'old' value of the property from before the file rename, which doesn't evaluate to anything in the newly named file so the text shows the 'raw' value. The only way to get the file to update seems to be to open the File Properties dialog, which shows the correct file name in the property 'Value/Text Expression' field. The text will update correctly even if you Cancel the Properties dialog.
Nice! That makes sense. I actually had a similar issue on how not to show decimal places. So for instance if I shortened it enough to show only one digit if I had 10 rows or columns it would only show "1". If I made it short enough to show 2 digits it would show "1." for single digits. I can't remember now but somewhere you have to set the decimal places to "none"...I think it may be the linear units.JSculley wrote: ↑Wed Sep 29, 2021 8:24 am It isn't 'D'. It is:
Also I never have figured how to make this do "A,B,C". I think the only possible way is to create a special font where the alphabet is shown rather than numbers. But I haven't tried that yet.
try to replace in the propertiesMJuric wrote: ↑Wed Sep 29, 2021 8:15 am That's pretty much what I tumbled too when I was working on it. There are few other combinations of actions that seem to force a rebuild, can't remember what they were, but most of those were not 100% and were more complex. Opening the file properties window and closing it seemed to work 100% of the time and was only one click.
"D2@Sketch7@Part1.SLDPRT" with "D2@Sketch7" (same for Sketch8)
save and close the part. copy and rename it on the desktop a couple of times and it regenerate correctly everytime since.
I'll have to try that. I have this in a driveworks model and if I can make it regen off the model that's one less thing I have to "Fix"
