Basic animation of a simple thing
Answers: 24
x 758
x 910
Motion Study Basic Animation
Is this the literally stupidest thing in the world? Or am I a complete idiot? GRRRR o[ o[ o[
I just spent the last hour trying to figure out how to create a simple animation of a swing clamp opening and closing and I cannot figure it out.
I can get 1 direction of movement. But then, once I try to add the rotational or another linear motion, then it seems to cancel out the original.
Absolutely NOTHING is intuitive! I look at the help files and it literally says:
And that is it. Might as well have said nothing.
I tried to look at videos of how people used a motor, and apparently no one has ever tried to do the same thing at all.
Are there any good tutorials out there on how to create a simple motion animation?
zxys001
x 2272
x 979
Re: Basic animation of a simple thing
Unread post by zxys001 »
dpihlaja wrote: Wed Oct 20, 2021 3:27 pm Motion Study Basic Animation
Hello Dan... what type of Swing Clamp mechanism? Do you have a simple example or image/video in how it articulates?
..here's my guess/example...
SwingArmClamp.zip
(363.79 KiB) Downloaded 49 times
x 2488
x 1894
@dpihlaja,
For something like this I'd reach out to my VAR. I don't do animations enough to be any good at it at all.
Answers: 13
x 2066
x 1731
This probably isn't much help. I'm not logging in to read the responses.
https://forum.solidworks.com/thread/101297
https://forum.solidworks.com/thread/33439
Every time I try and do a motion study it takes me half the day to remember how to properly define the motor.
Edited to add:
https://www.atlantis-press.com/article/25901888.pdf
MJuric
x 873
Unread post by MJuric »
I've spent many hours banging my head doing what I think should be "Simple" things to get an animation. To me this is pretty poorly put together in SW.
Simple things like resetting a view seem like a Rubic's cube to figure out.
For motors- Make sure that there isn't something keeping it from moving, mates, other parts etc. When you think you have it going the right way because you have the arrow going the direction that makes sense....it's probably backwards.
The "Timeline" is absolutely brutal, in my opinion. If you try and change things and haven't set something to the right point it changes it in an odd position and then you can't get rid of it and on an on.
I really can't offer an intelligible advice because every time I think I have something figured out it stops working. My only advice is, no, it's really that stupid and even if you read the tutorials, watch videos, most of what you read and watch won't work quite like shown. At least that has been my experience.
Answers: 55
x 8
x 833
Unread post by JSculley »
Don't use motors. Position the clamp in the starting position. Drag the time bar to a future time and right click to add a key frame. Then drag your clamp open or closed, rotate it and what not. SW Motion will interpolate the motion in between. I'm home now, but I'll try to create a simple example in the morning.
Answers: 13
x 2066
x 1731
You've saved me hours the next time I need to do a motion study.
Lucas
x 175
x 170
Unread post by Lucas »
Try choosing "Distance" in Motion. For a Rotary Motor you will set an angle and for Linear Motor a measure. Also set the Start Time and Duration Time. Then press Calculate
Motor.SLDASM
(119.98 KiB) Downloaded 69 times
Lucas
x 175
x 170
Also about the problem with the motors interfering themselves, if you add another Motor with the same type of motion the first one won't move.
To solve this you need to create a Off Key using RMB (this will suppress the Motor), drag it to a time before the next Motor starts.
Also the last Motor must start after the first one finishes it movement.
If two Motors of the same type are unsuppressed during a determined time, a motion will not occur at that interval - or might have some strange results. (Check Motor 3 - to fix it drag the LinearMotor2 Key Point past the 4 sec mark)
Motor3.SLDASM
(126.29 KiB) Downloaded 78 times
Motor2.SLDASM
(122.06 KiB) Downloaded 60 times
Answers: 55
x 8
x 833
JSculley wrote: Wed Oct 20, 2021 5:09 pm I'm home now, but I'll try to create a simple example in the morning.
Like this (click to view screen recording):
Answers: 24
x 758
x 910
Lucas wrote: Thu Oct 21, 2021 3:35 am Also about the problem with the motors interfering themselves, if you add another Motor with the same type of motion the first one won't move.
I think that this is the issue that I was running into.
I am not sure that this is documented anywhere.
Thank you
Answers: 24
x 758
x 910
MJuric wrote: Wed Oct 20, 2021 4:32 pm I've spent many hours banging my head doing what I think should be "Simple" things to get an animation. To me this is pretty poorly put together in SW.
I am really glad that I am not the only one. LOL
x 2488
x 1894
The whole keyframe editing thing is difficult to get your head into. I had played around with some video editing software that used it and it was confusing there. But with SW it seems even more difficult. The way it works isn't intuitive to me. VARs are trained on how to do it the right way. May want to give reaching out to them a try.
Answers: 24
x 758
x 910
zxys001 wrote: Wed Oct 20, 2021 3:40 pm Hello Dan... what type of Swing Clamp mechanism? Do you have a simple example or image/video in how it articulates?
Yes, your picture looks like the type of swing clamp I am working on. Basically, it rotates into position while moving downward for clamping.
I think that you are using a SW version that is newer than mine. I am using SW 2018 SP5.
I was trying to use a motor, and, while I could get 1 motor to work, as soon as I added the 2nd one, all movement stopped.
I just couldn't figure out why.
Answers: 24
x 758
x 910
OK, obviously. I was frustrated yesterday.....
I will look back into it again today.
Thank you all for the great responses!
Lucas
x 175
x 170
dpihlaja wrote: Thu Oct 21, 2021 8:41 am I think that this is the issue that I was running into.
Thank you
Glad to help. I also learned it today :lol:
JSculley wrote: Thu Oct 21, 2021 7:50 am Like this (click to view screen recording):
Pretty cool method, thanks for sharing UU
x 192
Unread post by Dwight »
For animation, I find it easiest to work with dimensioned linear mates and dimensioned angle mates, then edit the dimensions. Motors are okay.
I like the keyframe controls, once I got used to them. Being able to cut and paste them is big, and mirroring is huge. Nice to create a series of moves then easily reverse the series to bring it back to start.
MJuric
x 873
dpihlaja wrote: Thu Oct 21, 2021 8:49 am Yes, your picture looks like the type of swing clamp I am working on. Basically, it rotates into position while moving downward for clamping.
Take this for what it's worth, a complete novice, but what about doing this with a single motor and actually making the cam for the rotate? Although making the cam path actually work might be just as tricky as using two motors :)
MJuric
x 873
JSculley wrote: Wed Oct 20, 2021 5:09 pm Don't use motors. Position the clamp in the starting position. Drag the time bar to a future time and right click to add a key frame. Then drag your clamp open or closed, rotate it and what not. SW Motion will interpolate the motion in between. I'm home now, but I'll try to create a simple example in the morning.
This has NEVER worked for me. I don't know if I'm missing some simple key point but I have NEVER been able to get the drag to position and interpolate to work....and I've tried A LOT because that is the simplest approach. Being able to do this would have saved me HOURS and HOURS on one animation I did for a presentation....it just wouldn't work for me....I was very angry when I just quite and used motors.
I use to have a video editing software that had similar abilities and it was easy peezy. Click, start phase out here, click, end phase out here...render...look it worked. I wanted SW to do that, it revolted.
