Automatic Solve Order
Tera
x 483
x 91
Unread post by Tera »
After so many years working in SW, still I fail to understand the logic behind equation order.
Can anyone explain why I'm receiving error in the following equation?
If I mouse over the yellow triangle I see the following message:
Warning: The equations are out of order. Try Activating "Automatic solve order"
If I follow the instructions in warning the order changes and the error is gone:
Why Z variable should be declared before X & Y? It's not used anywhere at all....
thanks for any kind of insight.
gupta9665
Answers: 25
x 436
x 455
Re: Automatic Solve Order
Unread post by gupta9665 »
Works OK for me so this could be a glitch. Try force rebuild or restart SW/machine.
Tera
x 483
x 91
Thanks for the reply and sorry for not being able to reach you sooner. I was in a business trip.
Seems that SW needs to be restarted to understand how the real orders should be.
In my case every time I change the order of equations, I have to restart SW to understand the new order has no problem
Thanks again.
gupta9665
Answers: 25
x 436
x 455
I would suggest to report to your VAR, could be an issue with the installation or DLL.
Answers: 30
x 1221
x 2011
Tera wrote: Mon Nov 01, 2021 8:42 pm Thanks for the reply and sorry for not being able to reach you sooner. I was in a business trip.
Thanks again.
I've seen something similar in the past as we use equations quite extensively. It didn't happen every time but when it did it required a restart of SolidWorks to fix. Seems some code in memory was corrupted. Can you share the file?
