In my drawing templet I have set a custom property for the sheet number, that the title block will look at to get its value.
I have set up a “Pull Down List” in the “Property Tab Builder” to be able to select/chose what I would like the custom property to be.
All is good EXCEPT when I chose “$PRP:”SW-Current Sheet” from the list.
I save the file:
It is good UNTIL I reopen the file and the “Evaluated Value” pops into the “Property Tab Builder” selection box.
Then all sheets in the file will take on the value of the sheet I am on when I open the “Property Tab Builder”
Note: My Assemblies are usually the only sheets that are multiple sheet files and they usually start with sheet No “1” If it is a detail sheet, the number comes from the model (or if I need to I can over ride that by picking from the list or just type in a number)
I just want to know if there is a way to prevent the “Evaluated Value” from filling in the PTB box upon reopening the file? Why can it not stick to “$PRP:”SW-Current Sheet” (the “Value/Text Expression”)
Anyone have any ideas to fix/work-around this? ( I know I can edit the Sheet Format for each consecutive sheet and make it stick to what I desire the "Sheet No" to be BUT was just wondering if there was another way. )
Thanks
Edit:
The --> $PRPSHEET:"Detail_Sheet_No"
works fine and sticks to the “Value/Text Expression” upon saving and reopening
Property Tab Builder & a Changeable/Selectable Value for Sheet Number Problem.
- Roasted By John
- x 268
- x 583
Re: Property Tab Builder & a Changeable/Selectable Value for Sheet Number Problem.
@Conklin
Check out the attached macro, I don't know if it will answer your question, but I have used this for multiple sheets for many years, one of the best macros.
The other option this macro gives you is that you can have a cover sheet in the drawing file and not have it show up in the Page # of Page #.
You will need to adjust the dimensions within the macro to have the note places properly.
- CustomSheetNumber.swp
- (102.5 KiB) Downloaded 68 times
www.martinsroastapig.com
Pig Roast Your Way
Pig Roast Your Way
I have tried the macro "CustomSheetNumber.swp"
I simplified the macro a bit to better understand what it was doing…
Took away the filter bit, made it to do just one size drawing format/templet size, commented out the graphics and zoom all bit
I also made the position and the font size good for my templet.
Am calling it “CustomSheetNumber-BOB.swp” for now Did this for it was not working right
For even prior to the simplification, it would work OK when I first Run it
BUT on a second run it would get hung up here And then go to here Run a third time it would get hung on sheet two
Run a fourth time and it would be OK again..
Not sure where or what needs to be changed BUT
It seems to hang or not delete a note with “SHT” in it sometimes and not hang or will delete the “SHT” note other times.
Note: I am testing it on a drawing with TWO sheets (Named “Sheet1” & “Sheet2”)
Just wondering where/how it goes BAD
thanks
thanks
