Pack and Go: save to folder dir
- christian chu
- x 31
- x 39
I tried to pack and go an assembly, the local drive in "Save to Folder" appeared as a server folder c:\\
Is there an option to change the folder back to c:\
Thanks
Thanks
Re: Pack and Go: save to folder dir
If you double-click the folder name, it should bring up an editing box to change it.
- christian chu
- x 31
- x 39
Got it. In my experience, it defaults to whatever folder the top level assembly resides in.
For a workaround, save it as a zip file and unpack that in the folder you want.
- x 1231
I have no advice to offer. I'd just like to know what kind of part is called a "Discriminator". ![Shocked :shock:](./images/smilies/icon_eek.gif)
- christian chu
- x 31
- x 39
We design and manufacture check scanners, https://www.digitalcheck.com, so this device is used to separate single check/document from a stack, similar as in printer machinemike miller wrote: ↑Fri Feb 04, 2022 3:42 pm I have no advice to offer. I'd just like to know what kind of part is called a "Discriminator".![]()
- x 2489
- x 1899
You should have lied to us...What a let down...I was hoping it was a pulse laser rifle or something fun...christian chu wrote: ↑Fri Feb 04, 2022 4:10 pm We design and manufacture check scanners, https://www.digitalcheck.com, so this device is used to separate single check/document from a stack, similar as in printer machine
Why not click on browse folder button in the pack and go window and select the desired path. This will change it for all the components.
- christian chu
- x 31
- x 39
Hi Deepak,
it's been a while ...
Glad to hear from you again. it's exactly what I tried to do - see att. image
- christian chu
- x 31
- x 39
it's my bad and I shouldn't post that image with that part's name. I believe it's not wise to bring this upmattpeneguy wrote: ↑Fri Feb 04, 2022 4:54 pm You should have lied to us...What a let down...I was hoping it was a pulse laser rifle or something fun...
Will be more careful next time
This is because you have "Keep full folder structure" option selected. Change it to "Flatten to single folder"christian chu wrote: ↑Sat Feb 05, 2022 1:03 pm Hi Deepak,
- christian chu
- x 31
- x 39
You will see this issue only when selecting the drive as path but not if you select a folder on the drive. This is an issue/bug in my opinion, so you should report.christian chu wrote: ↑Sun Feb 06, 2022 11:55 pm I want "keep full folder structure" option. Why there is extra "\" after the drive letter
Below is the reason for the issue
Original Path
C:\SOLIDWORKS\Sample Files\Joint Assy
New path selected
D:\
"keep full folder structure" option selected
New Final Path will be
D:\ + \SOLIDWORKS\Sample Files\Joint Assy = D:\\SOLIDWORKS\Sample Files\Joint Assy
