Convert Entities
x 2222
x 1869
Convert Entities
Is it possible to have Convert Entities convert the entire face at once? I always have to run the command at least twice if there is an inner loop. (And if I do the outer loop first, I have to select the inner edges one at a time. I can't just select the face.)
by Alin » Thu Feb 10, 2022 8:49 am
So, the current solution is to run Intersection Curve instead of Convert Entities. It will capture all edges that are laying on the sketch plane.
It is also a much more robust feature than Convert Entities. If new holes are added on that face, they will be automatically captured by a rebuild operation.
Alin
x 265
x 391
Re: Convert Entities
Unread post by Alin »
If it is a planar face, coincident to the sketch plane, use the Intersection Curve.
Alin
x 265
x 391
Also this:
x 2222
x 1869
That gives me the inner loops, but I have to run the command again to get the outer loops. Am I doing it wrong? (click on GIF below)
Alin
x 265
x 391
SPerman wrote: Wed Feb 09, 2022 2:01 pm That gives me the inner loops, but I have to run the command again to get the outer loops. Am I doing it wrong? (click on GIF below)
Try to check the box first.
x 2222
x 1869
That still only selects the inner loop for me. (2020 SP5)
Alin
x 265
x 391
SPerman wrote: Wed Feb 09, 2022 2:36 pm That still only selects the inner loop for me. (2020 SP5)
But you have only one inner loop.
Alin
x 265
x 391
Send me the file, please.
x 2222
x 1869
I want it to select the inner and outer loops at the same time.
Frank_Oostendorp
x 183
x 229
Alin wrote: Wed Feb 09, 2022 2:18 pm Try to check the box first.
I am curious as well, is there a way to select all loops (inner and outer) to convert their entities to a sketch, Alin?
RonE
x 18
x 33
Unread post by RonE »
I think currently the UI doesn't provide a way to do it but API does. :D
Option Explicit
Sub main()
    Dim swModel As ModelDoc2
    Dim swSelMgr As SelectionMgr
    Dim swFace As Face2
    Dim EdgeArr() As Edge
    Dim swSketch As Sketch
    Dim swSketchManager As SketchManager
    Set swModel = swApp.ActiveDoc
    If swModel Is Nothing Then Exit Sub
    Set swSketch = swModel.GetActiveSketch2
    Set swSketchManager = swModel.SketchManager
    If swSelMgr.GetSelectedObjectType3(1, -1) = swSelectType_e.swSelFACES Then
        Set swFace = swSelMgr.GetSelectedObject6(1, -1)
    End If
    If swSketch Is Nothing Then Exit Sub
    If swFace Is Nothing Then Exit Sub
    EdgeArr = swFace.GetEdges
    If IsEmpty(EdgeArr) Then Exit Sub
    swModel.Extension.MultiSelect2 EdgeArr, False, Nothing
    swSketchManager.SketchUseEdge2 False
Answers: 25
x 807
x 978
Alin wrote: Wed Feb 09, 2022 2:37 pm But you have only one inner loop.
He is trying to grab both the inner loops and the outer loops at the same time
Alin
x 265
x 391
I stand corrected. The Property manager reports all entities are selected, but the command converts only the inner contours. o[
Alin
x 265
x 391
x 2222
x 1869
Alin wrote: Thu Feb 10, 2022 8:49 am So, the current solution is to run Intersection Curve instead of Convert Entities. It will capture all edges that are laying on the sketch plane.
That's great to know. I will use that in the future.
