Sketch Constraint Size
SteveH
Unread post by SteveH »
Is there a setting to increase the size of the constraint flags in sketches on high resolution monitors? My monitor resolution is 3840 x 2160 (Recommended) and I find that the constraints are difficult for me to resolve. I'm currently using SolidWorks 2022 SP1 on Windows 10 but I've been struggling with this issue since SW2018 when I upgraded to these monitors.
Answers: 26
x 824
x 1011
Re: Sketch Constraint Size
Unfortunately no (as of SW 2018 anyway).
You CAN however, vote for SPR 681941
I would add a picture, but I am getting the HTTP error again ( @matt ) when I try to add it (either by copying and pasting it in, or by trying to manually add it as an attachment)
https://r1132100503382-eu1-3dswym.3dexp ... -QFnFX4b6g
x 1225
x 2391
SteveH wrote: Thu Feb 24, 2022 2:32 pm Is there a setting to increase the size of the constraint flags in sketches on high resolution monitors? My monitor resolution is 3840 x 2160 (Recommended) and I find that the constraints are difficult for me to resolve. I'm currently using SolidWorks 2022 SP1 on Windows 10 but I've been struggling with this issue since SW2018 when I upgraded to these monitors.
In the monitors section of the Windows settings, you can set a percentage to make interface elements larger, like 125%. Does that change the icon size?
@DanPihlaja Yeah, I'm getting the same thing. The host just forced upgraded everyone to PHP 8.0, but phpbb doesn't work with that so I set us back to 7.4. Hopefully that resolves things...
MattW
x 5
x 36
Unread post by MattW »
I'm not answering your question directly, but I have a mouse gesture to toggle constraint display and it gets used a lot.
SteveH
matt wrote: Thu Feb 24, 2022 3:11 pm In the monitors section of the Windows settings, you can set a percentage to make interface elements larger, like 125%. Does that change the icon size?
Thanks for the suggestion. My current setting is 175%. I increased that to 300%, restarted SolidWorks and saw no effect (other than great big desktop icons and start menu).
SteveH
DanPihlaja wrote: Thu Feb 24, 2022 2:57 pm I would add a picture, but I am getting the HTTP error again ( @matt ) when I try to add it (either by copying and pasting it in, or by trying to manually add it as an attachment)
When I added that picture in my original post I started by dragging it into the edit window. Then I selected "inline" from the attachment options.
Answers: 26
x 824
x 1011
MattW wrote: Thu Feb 24, 2022 3:20 pm I'm not answering your question directly, but I have a mouse gesture to toggle constraint display and it gets used a lot.
Do you mean the hiding and showing of constraints?
Or do you mean the display size?
x 1225
x 2391
SteveH wrote: Thu Feb 24, 2022 3:33 pm Thanks for the suggestion. My current setting is 175%. I increased that to 300%, restarted SolidWorks and saw no effect (other than great big desktop icons and start menu).
Oh, ok, well, now we know that isn't the solution! ()
x 2332
x 1956
I remember on the old forum there were complaints that SW wasn't 4K ready.
SteveH
DanPihlaja wrote: Thu Feb 24, 2022 4:04 pm Do you mean the hiding and showing of constraints?
The display size.
I've done quite a bit of searching for this issue. I didn't find a lot of complaints about it. Could be my eyeglasses are wearing out.
MattW
x 5
x 36
Hiding and showing. The issue is, seeing constraints can be useful. But they can also be in the way a lot, especially if you find them too big. So a quick toggle to turn them on when you need them and off when you don't is how I have it addressed. As I said, doesn't answer the question, just a way to deal with the issue.
