DanPihlaja wrote: ↑Thu Mar 10, 2022 11:10 am
Had you just opened the part?
In other words, was the graphics loaded, but not the geometry yet?
Do you have this unchecked?
Hello Dan,.. yes, I have always had that setting checked on. and yes, it was after I first opened and tried to edit a sketch and the greyed out convert entities.
Then, the graphics or line entities are not loaded until something triggers a entities refresh? (this is new to me, never seen it before)
So, flipping between that test open/edit part may have triggered the menu graphics to flip on after the refresh the line graphics (which were dumb)?
This is something new I have never encountered.
Is this a known issue among you guys when sharing SW data?
To be clear,.. the data was part of a Sub Assy.. so it was already loaded in the background. It was the first time I had opened directly to edit. Then the background data is just in graphics mode still and full edit mode is not available until..... what?... a refresh or... what specifically triggers edit access to the geometry?
![cheers UU](./images/smilies/clinky.gif)
