Is there a way of choosing what columns are visible in the PDM add-in while inside SW? There's plenty of documentation on how to add/change columns in the main File Explorer (which I have successfully changed) but I haven't seen anything for changing the add-in view.
I'd like to add the Revision column to this view.
We've only got PDM Standard if that's a noteworthy limitation.
Choose Columns in PDM Add-in?
- x 47
- x 372
The PDM Add-in settings are under Tools -> SOLIDWORKS PDM -> Options...
Then from the "Information to display" dropdown select what you want and adjust the check boxes for if and how to display it.
Go to full postThen from the "Information to display" dropdown select what you want and adjust the check boxes for if and how to display it.
Re: Choose Columns in PDM Add-in?
- x 47
- x 372
Ace, thanks!
