berg_lauritz wrote: ↑Thu Jun 02, 2022 11:31 am
How is that an alternate process? The PDF/DXF is generated through PDM or on your own machine?
The step files are not generated by PDM?
Why is the PDF viewer important here? Does PDM lock a PDF to be read only if it's saved to a different location?
Edit: Great replies already, thank you!
We don't have PDM, so I don't know how PDM acts, but nothing is generated by PDM. All is user generated.
Every save of drawing creates a PDF, along with a DXF if the DXF exists.
Every step file is generated by a script ran at night on a user computer that creates them based on if they're outdated(very roughly explained)
We use CustomTools, and our ERP is Prextra.
Prextra has it's own command on SolidWorks that I have assisted with the implementation of and also the continuous improvement.
CustomTools is used as our project manager and is also used to create our custom properties. It has a few cool features on it like DXF creation, where used, file conversion, task running, plus the support we get from them is simply outstanding to say the least. The support we have gotten from Dassault is "okay", to keep it polite, so we decided that if the support was as great on PDM as it is on SolidWorks, that we were better of with an alternative to it and with developping whatever else we required that wouldn't be covered by CustomTools.
For the PDF Viewer, PDM isn't the issue, Adobe Reader is. If anyone has the file opened in Adobe Reader, or in the preview of Windows Explorer, then the file will be locked in Read Only and PDM wouldn't be able to overwrite it technically, like it happens for us when we try to overwrite a file opened on Adobe Reader.
All our files are on our server, shared across multiple companies.
Edit here's a screenshot to give you an idea what CustomTools gives us capabilities of
