How SolidWork records file open time?
Programming and macros
JuTu
x 55
x 35
Unread post by JuTu »
Hi again!
I've been working on an in-house Performance benchmarking system and am now considering options to macro-fy some of the tasks.
I have been looking for some hint or notation how or where SolidWorks save the file open time and could it be read with a macro. The thing is that we use 3rd-party PDM and it seems that I need to instruct users to manually open some files from the vault since I think it is not accessible via VBA.
All in all, I want to read and show the user the time that SolidWork registered as 'Open time' which means that document is opened first and then the macro is run by user. Assembly visualization uses 'SW-Open time' as column header and file open time can be seen from file info when cursor is hovered over the file in Windows file explorer.
Any hints? I will continue my research tomorrow, but if I can't find a solution, I will proceed with more manual labor intensive methods.
TIA!
Sincerely,
JuTu
__________________
Lentäjä on ulkona ja lukossa.
mike miller
x 1070
x 1231
Re: How SolidWork records file open time?
Unread post by mike miller »
I don't know how SWX records it, but I know it can be way off the deep end sometimes.
Answers: 55
x 878
Unread post by JSculley »
JuTu wrote: Tue May 24, 2022 9:46 am All in all, I want to read and show the user the time that SolidWork registered as 'Open time' which means that document is opened first and then the macro is run by user. Assembly visualization uses 'SW-Open time' as column header and file open time can be seen from file info when cursor is hovered over the file in Windows file explorer.
Any hints?
When you open a SOLIDWORKS file, it is recorded in the FileAccess.log file that SOLIDWORKS creates in the %APPDATA%\SOLIDWORKS folder. The data looks like this:
05/24/2022 14:46:12 OPEN "E:\_EPDM\engineering\oracle\401xxx\401480.SLDPRT"
05/24/2022 14:46:12 OPEN "E:\_EPDM\engineering\oracle\400xxx\400347.SLDPRT"
05/24/2022 14:46:12 OPEN "E:\_EPDM\engineering\oracle\1xxxxx\125665.SLDPRT"
05/24/2022 14:46:13 OPEN "E:\_EPDM\engineering\oracle\400xxx\400348.SLDPRT"
05/24/2022 14:46:13 OPEN "E:\_EPDM\engineering\oracle\400xxx\400349.SLDPRT"
05/24/2022 14:46:13 OPEN "E:\_EPDM\engineering\oracle\421xxx\421028.SLDPRT"
05/24/2022 14:46:13 OPEN "E:\_EPDM\engineering\oracle\1xxxxx\109348.SLDPRT"
05/24/2022 14:46:13 OPEN "E:\_EPDM\engineering\oracle\414xxx\414893.SLDPRT"
05/24/2022 14:46:13 OPEN "E:\_EPDM\engineering\oracle\414xxx\414894.SLDPRT"
05/24/2022 14:46:14 OPEN "E:\_EPDM\engineering\oracle\414xxx\414896.SLDPRT"
05/24/2022 14:46:14 OPEN "E:\_EPDM\engineering\oracle\414xxx\414897.SLDPRT"
If you are opening an assembly, a crude approach would be to find the delta between the first and last timestamps.
MattW
x 5
x 33
Unread post by MattW »
mike miller wrote: Tue May 24, 2022 10:09 am I don't know how SWX records it, but I know it can be way off the deep end sometimes.
I could use this information now, and I have apparently dismissed this message. I am not seeing it my dismissed messages in System Options. Anyone know what this is called?
Answers: 55
x 878
Assembly Open Progress Indicator:
x 2373
x 2015
Sometimes, the counter keeps rolling if you don't close the window and you end up with numbers like that. I don't know what makes the counter keep on going though.
MattW
x 5
x 33
JSculley wrote: Thu Jul 21, 2022 3:11 pm Assembly Open Progress Indicator:
Didn't have that one listed, but there was one listed for "Drawing open Progress Indicator". That seems to have done it.
Answers: 55
x 878
MattW wrote: Thu Jul 21, 2022 7:56 pm Didn't have that one listed, but there was one listed for "Drawing open Progress Indicator". That seems to have done it.
There are individual dialogs for each document type:
starshiphalo2333
Unread post by starshiphalo2333 »
I add this code to my macros that I want to log/show the process time (open, save, rebuild, etc).
Dim nStart  As Single
Dim TimeElasped As String
nStart = 0
nStart = Timer
'***Process/Task Code Here***
TimeElasped = Format((Timer - nStart) / 86400, "hh:mm:ss")
MsgBox "This model opened in " & TimeElasped & " (hours:minutes:seconds)"
