Windows Recent File List
This is going to be a strange one. Hopefully I can describe it properly.
If I do a "Save as PDF" on a drawing, and then go to outlook, that pdf appears in my "Recent Items" list (for example, if I want to attach that file to an email.)
However, if I run the macro I created that does the same "Save as PDF" process, it does NOT appear in my "Recent Items" list. Do any of you API guru's know if I can add something to my macro to change this behavior?
Re: Windows Recent File List
Add this enum to your namespace:
public enum ShellAddToRecentDocsFlags
Pidl = 0x001,
Path = 0x002,
PathW = 0x003
[DllImport("Shell32.dll", BestFitMapping=false, ThrowOnUnmappableChar=true)]
private static extern void SHAddToRecentDocs(ShellAddToRecentDocsFlags flag, [MarshalAs(UnmanagedType.LPStr)]string path);
mExt.SaveAs(path, (int)swSaveAsVersion_e.swSaveAsCurrentVersion, (int)swSaveAsOptions_e.swSaveAsOptions_Silent, exportData, ref errors, ref warnings);
SHAddToRecentDocs(ShellAddToRecentDocsFlags.Path, path);
This is exactly what I was looking for. Thank you!
- CarrieIves
- x 402
- x 153
@JSculley ,
My save as PDF macro is in VBA. Are the code snippets you provided in VBA or something else? I'm still learning my way around macros for SolidWorks.
Thanks,
Carrie
Thanks,
Carrie
The snippets are C#. You can do the same sort of thing with VBA. Add these constants:CarrieIves wrote: ↑Tue Jan 25, 2022 11:20 am My save as PDF macro is in VBA. Are the code snippets you provided in VBA or something else? I'm still learning my way around macros for SolidWorks.
Const Pidl = 1
Const Path = 2
Const PathW = 3
Private Declare PtrSafe Sub SHAddToRecentDocs Lib "shell32" _
(ByVal uFlags As Long, ByVal pv As Any)
SHAddToRecentDocs Path, filePath
- CarrieIves
- x 402
- x 153
@JSculley THANKS
I tested it this morning and it works perfectly. Thanks again @JSculley
- Jaylin Hochstetler
- x 380
- x 355
FYI,
If you ever want to do this in .NET, which I did recently your code needs to look like this
Granted, I'm sure there are other ways of doing it too.
Public Enum ShellAddToRecentDocsFlags
Pidl = &H1
Path = &H2
PathW = &H3
End Enum
<DllImport("Shell32.dll", BestFitMapping:=False, ThrowOnUnmappableChar:=True)>
Private Shared Sub SHAddToRecentDocs(ByVal flag As ShellAddToRecentDocsFlags,
<MarshalAs(UnmanagedType.LPStr)> ByVal path As String)
