DeleteScene Method (IModelDocExtension)
Programming and macros
gerard
x 6
x 35
Unread post by gerard »
All,
I'm tweaking my clean up utility to be able to unfiy the scene settings in my parts/assemblies.
Doing some spelunking I've come across the DelecteScene function: https://help.solidworks.com/2017/Englis ... Scene.html
To be kind, documentation is kinda sparse.
Has anyone gotten this to work? More importantly has anyone gotten this to work under VBA?
Thanks
Answers: 55
x 864
Re: DeleteScene Method (IModelDocExtension)
Unread post by JSculley »
It pretty much works as advertised. Here's a before:
Here's some code:
Dim mDoc As ModelDoc2
Dim mExt As ModelDocExtension
Sub main()
    Set mDoc = swApp.ActiveDoc
    Set mExt = mDoc.Extension
    mExt.DeleteScene
And here's the after:
AlexB
Answers: 27
x 257
x 432
Unread post by AlexB »
It works for me when I run my code, but I had to test a few things to make sure I knew what was going on.
You can delete a scene, however there needs to be a scene applied to the part so SW re-applies the default theme. This is why it doesn't appear that the scene is deleted from the feature tree.
gerard
x 6
x 35
JSculley wrote: Wed Feb 15, 2023 7:45 am It pretty much works as advertised. Here's a before:
Here's some code:
Sub main()
    mExt.DeleteScene
Works perfectly.
Thank you
