Drawing Labels
m2shell
x 121
x 56
Drawing Labels
Unread post by m2shell »
Is there a way to set the automatic Section & Detail labeling so that if I have a multi-sheet drawing, it will have labels start at "A" for each sheet in the drawing file?
x 1751
x 2124
Re: Drawing Labels
m2shell wrote: Tue May 16, 2023 3:16 pm Is there a way to set the automatic Section & Detail labeling so that if I have a multi-sheet drawing, it will have labels start at "A" for each sheet in the drawing file?
I'm pretty sure the answer is no. Why would you want to?
m2shell
x 121
x 56
Re: Drawing Labels
Drawing starts out single sheet, becomes multiple sheets, then later gets split into separate drawings. For instance Part detail sheets get worked on a separate sheet than the installation context drawings. Then file gets too big and slow, so it has to get split into separate files.
x 2489
x 1899
Re: Drawing Labels
You can try the following macro when you separate the sheets out. It'll rename the views starting with A.
    Const A_CHAR As Integer = 65
    Const Z_CHAR As Integer = 90
    Dim swSheet As SldWorks.Sheet
    Dim curChar As Integer
    Dim curChar2 As Integer
    Dim curChar3 As Integer
    Sub main()
        Set swDraw = swApp.ActiveDoc
        If swDraw Is Nothing Then
            MsgBox "Please open drawing document"
            End
        End If
        Dim vSheetNames() As String
        vSheetNames = swDraw.GetSheetNames
        Dim sheetInd As Integer
        curChar = A_CHAR
        curChar2 = A_CHAR
        curChar3 = A_CHAR
        For sheetInd = 0 To UBound(vSheetNames)
            swDraw.ActivateSheet vSheetNames(sheetInd)
            Set swSheet = swDraw.Sheet(vSheetNames(sheetInd))
            Dim vViews As Variant
            vViews = swSheet.GetViews
            Dim i As Integer
        'Debug.Print UBound(vViews)
            'If UBound(vViews) Is Nothing Then
            ' if sheet has no views skip
            'Else
            For i = 0 To UBound(vViews)
                Dim swView As SldWorks.View
                Set swView = vViews(i)
                Select Case swView.Type
                    Case swDrawingViewTypes_e.swDrawingSectionView
                        Dim swSectionView As SldWorks.DrSection
                        Set swSectionView = swView.GetSection
                        Debug.Print swSectionView.GetLabel
                        swSectionView.SetLabel2 GetNextName
                    Case swDrawingViewTypes_e.swDrawingDetailView
                        Dim swDetailedView As SldWorks.DetailCircle
                        Set swDetailedView = swView.GetDetail
                        Debug.Print swDetailedView.GetLabel
                        swDetailedView.SetLabel GetNextName
                End Select
            Next
            'End If
        Next
        swDraw.ForceRebuild
    Function GetNextName() As String
        If curChar > Z_CHAR Then
            If curChar2 > Z_CHAR Then
                MsgBox ("Overflow")
                End
            Else
                If curChar3 > Z_CHAR Then
                    curChar3 = A_CHAR
                    curChar2 = curChar2 + 1
                End If
'                FirstLet = curChar2
'                SecondLet = curChar3
                GetNextName = Chr(curChar2) & Chr(curChar3)
                curChar3 = curChar3 + 1
            End If
        Else
            GetNextName = Chr(curChar)
            curChar = curChar + 1
        End If
    End Function
x 2489
x 1899
Re: Drawing Labels
Fair warning though, it was made for a drawing file with multiple sheets. I suppose you could modify it to iterate through each sheet in the drawing and rename starting with A for each sheet. But, because the file already has an "A" view when you get to sheet 2, it will probably give you an error.
m2shell
x 121
x 56
Re: Drawing Labels
mattpeneguy wrote: Tue May 16, 2023 4:03 pm You can try the following macro when you separate the sheets out. It'll rename the views starting with A.
Great Thanks! I'll definitely try it out!
x 2489
x 1899
Re: Drawing Labels
Good luck and let us know how it works. If you modify it to work on a multisheet drawing with each sheet starting at "A", post it back here for others who may get use out of it.
Credit to where credit is due, Deepak Gupta helped me with that macro several years ago on the old forum.
I'm not really a coder, but I can kludge things together with some help from people who know what they're doing.
