Trying to Radius Complex Surface
Crowley723
Unread post by Crowley723 »
Hello all!
I just want to preface this with this. I am still fairly new to the CAD scene, I use Solidworks to design parts to print on my 3d printer. I am attempting to create a model for an existing handle for a scanner. I have gotten this far and the side profile is extremely close(still some tweaking to do).
I was hoping to be pointed in the right direction. I want to round out the edges to make it more like something someone could easily grab onto. I have tried using the fillet tool to no avail.
Any suggestions would be much appreciated.
Crowley723
by matt » Mon Jun 19, 2023 9:10 pm
Crowley723 wrote: Mon Jun 19, 2023 3:45 pm Ideally, it would look something like this.
Thanks for the quick response.
Yeah, you're not going to get that with fillets. Start here: https://episodes.dezignstuff.com/blog/
x 1211
x 2358
Re: Trying to Radius Complex Surface
Can you imagine/describe the shape you're trying to make? The edge around the handle is long with a lot of potential error points. Using a variable radius fillet will be one way to go.
Also, the part has a very extruded look. If you really want a more organic 3d rounded shape, you have to approach this differently with surfaces. How to do that is a different set of discussions.
Crowley723
x 1211
x 2358
Crowley723
Okay. Thanks I will look into it.
zxys001
Answers: 5
x 2294
x 989
Unread post by zxys001 »
Thought I'd play.. not quite right but a fun shape.. :D
Krzysztof Szpakowski
x 58
x 75
Unread post by Krzysztof Szpakowski »
matt wrote: Mon Jun 19, 2023 9:10 pm
Maybe not exactly as in the photo, maybe not A-class surfaces, but you can only use rounding
And now a bit towards A-class surfaces, ta-dam! ><
And as you can see below, the model prepared in this way can be used not only for home 3D prints
