Odd behavior when untrimming an extruded arc
ryan-feeley
x 90
Unread post by ryan-feeley »
Thought I'd share this to see if anyone else has seen similar oddities with untrim. This was created in Swx2020, but I've confirmed Swx2022 has the same behavior.
If I have an arc sketched on the top plane, sketched left-to-right such that the first arc endpoint is to the left and the 2nd is to the right, and extrude it as a surface in the +Y direction, it will untrim just fine
If instead I extrude it in the -Y direction, only half of the surface will untrim.
If I reverse the sketching direction, such that the first arc end point is to the right, and again extrude it as a surface in the -Y direction, it won't untrim at all.
I expect untrim to do better and worse at times with tolerant NURBS geometry. But I was very surprised that it can't reliably handle a simple analytic (cylindrical) surface. Can anyone venture a guess as to why? I'm curious if this is a solidworks issue or a parasolid kernel issue.
Untrim Failures.SLDPRT
(70.78 KiB) Downloaded 38 times
Answers: 55
x 864
Re: Odd behavior when untrimming an extruded arc
Unread post by JSculley »
Might be described in this KB article:
Article ID : SPR1240822
Abstract : Parts, Surface - Trim, Untrim: Untrim - It is not possible to untrim a cylinder due to the position and direction of a cut extrude feature
Link : https://support.3ds.com/knowledge-base/ ... SPR1240822
Listed as implemented in 2024 b1.
ryan-feeley
x 90
Thanks @JSculley! Based on the title that looks like exactly the same sort of root cause.
I couldn't make the `support.3ds.com` knowledgebase link work. Sadly it came up "search yielded no results".
Answers: 55
x 864
ryan-feeley wrote: Tue Jul 11, 2023 1:55 am Thanks @JSculley! Based on the title that looks like exactly the same sort of root cause.
This is the entirety of the report:
So, not much help but if it is the same issue, the 2024 Beta has begun and you could download it and check it out.
ryan-feeley
x 90
Thanks! I reset my password with 3ds, and now the link works. Not sure if it was a password issue, or if they had server-side issues yesterday. I will experiment with the 2024 Beta.
zxys001
Answers: 5
x 2294
x 989
Unread post by zxys001 »
ryan-feeley wrote: Fri Jul 07, 2023 1:50 pm
Hello Ryan... BUG! thanks for sharing this..., it's something I've seen for years, it's not uncommon with either nurbs or analytical arc untrims.
yeah, the only difference is the +Y extrude directions and this changes per plane? and if you export/import they still have issues, it Wierd! <()>
