SOLIDWORKS pet peeves
x 1821
x 2170
Re: SOLIDWORKS pet peeves
Zhen-Wei Tee wrote: Tue May 16, 2023 8:49 pm Attached below.
Sorry not really
I am aware of the hierarchy (in fact it is showing the appearance at hierarchy level). It is a part file and only has one part appearance without any other appearance
I played with it a little bit. The only way I've been able to change the color for the whole Part was to apply an appearance to a single face, copy it, select another face and Ctrl+A to select all, right-click, and paste the appearance.
Answers: 55
x 896
Unread post by JSculley »
Zhen-Wei Tee wrote: Mon May 15, 2023 10:42 pm sometimes the solidworks appearance is just driving me nuts
only one appearance apply at part level, but it is not showing in graphic o[
(seem to happen most frequently on part save from assembly, aka Save as Part from assembly)
This is because the imported body features have appearances, but they aren't listed in the Property Manager Pane. However, they are listed in the popout appearances panel:
You can remove them in one shot via the feature tree:
SPR 1217395 -- Appearance applied on a imported body 'Feature' cannot be removed
Not technically accurate since they can be removed.
Answers: 26
x 830
x 1029
JSculley wrote: Wed May 17, 2023 9:38 am This is because the imported bodies have appearances, but they aren't listed in the Property Manager Pane. However, they are listed in the popout appearances panel:
A technical correction:
That appearance in your picture is applied to the "features" that create the bodies. Not the bodies themselves. If the appearance had been added to the bodies, then the appearance would show up under the bodies folder.
Answers: 33
x 1274
x 2070
https://help.solidworks.com/2023/englis ... rarchy.htm
Each level overrides the one to the right.
Assembly Component > Face > Feature > Body > Part
Looks the import model code has a bug that doesn't update the internal table that holds the appearances values in that tab.
Answers: 55
x 896
DanPihlaja wrote: Wed May 17, 2023 10:42 am A technical correction:
Correct. I've edited my post to clarify.
x 2371
x 1986
I just opened a part from a vendor that I need to make some modifications to. I'm going through the long history tree, figuring out what I can suppress and what needs to stay. There are 2 fans on the end of the unit, with protective grills.
The step cut into the end of the part was duplicated with a linear pattern.
However, the 25 features that create the grill was duplicated for the 2nd grill.
x 1821
x 2170
SPerman wrote: Wed May 24, 2023 11:48 am I just opened a part from a vendor that I need to make some modifications to. I'm going through the long history tree, figuring out what I can suppress and what needs to stay. There are 2 fans on the end of the unit, with protective grills.
Maybe someone tried to pattern the grills also, but it didn't work because he or she didn't know to de-select "Features to Pattern" and select "Bodies to Pattern" instead?
x 2371
x 1986
Based on what I am finding in the tree, whoever did the work wasn't very proficient in SW.
x 2371
x 1986
On every single feature, I'm having to change this to "all bodies."
x 1821
x 2170
SPerman wrote: Wed May 24, 2023 3:58 pm On every single feature, I'm having to change this to "all bodies."
It sounds like a fun time. I'm so glad I almost never have to deal with anyone's models other than mine.
x 2585
x 1433
Glenn Schroeder wrote: Wed May 24, 2023 4:23 pm It sounds like a fun time. I'm so glad I almost never have to deal with anyone's models other than mine.
Some of you never have to work with other people's models and it really shows.
x 1821
x 2170
Solidworks crashed on me in the middle of working on a drawing a little while ago. I had saved often while working on it, including not long before the crash, but it somehow wiped out everything I had done in the last 3 hours (it crashed around 2:00 pm, but the drawing shows it was last saved at 10:51 am). How's everyone else's Friday going?
I've had very few crashes with SW2023, but this was a bad one.
AlexB
x 278
x 463
Unread post by AlexB »
Glenn Schroeder wrote: Fri Jul 21, 2023 3:11 pm Solidworks crashed on me in the middle of working on a drawing a little while ago. I had saved often while working on it, including not long before the crash, but it somehow wiped out everything I had done in the last 3 hours (it crashed around 2:00 pm, but the drawing shows it was last saved at 10:51 am). How's everyone else's Friday going?
Are you me? I literally just lost everything I worked on with an assembly from this morning. I clicked save probably 100 times while working for several hours but apparently it wasn't behaving... Not a single thing I did was saved. (2021 here) o[
TTevolve
x 89
x 181
Unread post by TTevolve »
39 minutes till it's a great Friday!
x 2585
x 1433
Would be going a lot better if I didn't care. Trying to focus on the positives.
x 2585
x 1433
With the Save File dialog open...
TTevolve
x 89
x 181
oh man, crashing while saving, that is the worst!
x 2585
x 1433
TTevolve wrote: Mon Jul 24, 2023 8:49 am oh man, crashing while saving, that is the worst!
After 1600 it's a toss, I just leave.
Damo
x 187
x 227
Unread post by Damo »
Interestingly, I am often frustrated that by default this is usually set to "Auto-select." Which generally means All Bodies anyway.
I work with multi-body parts, a lot, and I almost always set a cut extrude to go "Through all." and only select the bodies I wish to apply.
This way, if bodies move because of changes I make, the cut continues through.
Another frustration I find is that when I pattern a cut extrude feature, it is again, by default set to "Auto-select" (Tacitly, All) bodies.
I musy ALWAYS change this setting to apply only to the bodies I require..
x 2371
x 1986
I really hope someone actually reads these things.
x 1671
x 1517
That's circular reference and ZTG.
Of course SW crashed to prevent you from creating a blackhole.
zwei
x 185
x 600
Unread post by zwei »
SPerman wrote: Mon Aug 14, 2023 3:29 pm I really hope someone actually reads these things.
ironically
a lot of the time, the error report crash on me too
so i get two crash from one crash ... wait... is this their one and two? :o
x 1671
x 1517
That's 2 for 1.
zxys001
Answers: 5
x 2329
x 1007
Unread post by zxys001 »
Frederick_Law wrote: Tue Aug 15, 2023 10:31 am That's 2 for 1.
or, a Three For.. ><
Answers: 33
x 1274
x 2070
Dassault error report department
x 2371
x 1986
Really. You can't process the other 1934 files because 1 has to be resolved? (PDM Checkin)
grumph o[
KennyG
x 45
x 200
Unread post by KennyG »
Gotta love stuff like that. And how do you know which one needs to be resolved?
x 2585
x 1433
KennyG wrote: Wed Dec 13, 2023 12:35 pm And how do you know which one needs to be resolved?
Sort by the errors/warnings column, brings them to the top (or bottom).
zwei
x 185
x 600
Still scratching my head around this...
Why did they change the GD&T tool in SW2022?
The amount of mouse click needed in the new tool is just frustrating
Want to change your GD&T? Make sure to double click on the "correct" area
Want to delete or change your datum? Make sure to double click on the correct datum box tool!
Want to change two or more datum? Double click on the first datum, change it, then double click on the second datum, change it, repeat as needed yay!
Accidentally add a datum that is not needed? There is no back button, make two extra step to delete it!
Right click on the feature frame will show u both the rmb menu and gd&t window... because why not?!
Answers: 33
x 1274
x 2070
zwei wrote: Thu Jan 18, 2024 6:03 am
Not sure if this changed in 2023 but I only have to double click initially to put it in edit mode. After that, single click in an area activates and allows typing immediately. Seems to work ok although I'd like a picture with some of the menu text to assist selecting the correct option.
There also appears to more options than the old one. My GD&T standards knowledge is rusty, looks like new options have been added such as "Indicators". Also guessing the MBD stuff drove the change as well.
zwei
x 185
x 600
jcapriotti wrote: Thu Jan 18, 2024 11:07 am Not sure if this changed in 2023 but I only have to double click initially to put it in edit mode. After that, single click in an area activates and allows typing immediately. Seems to work ok although I'd like a picture with some of the menu text to assist selecting the correct option.
TIL something... Never thought of clicking it again after the window show up....
o[
x 2371
x 1986
Sometimes Solidworks is too smart for my own good.
If I wanted a hinge constraint, I would have picked a hinge constraint. For some reason SW decides any cylindrical feature should get this constraint. (Kind of like SW thinks all construction lines are centerlines.)
Click me! I'm a GIF.
CarrieIves
x 409
x 155
Unread post by CarrieIves »
There isn't a good way to get a list of all the settings for a document or all the settings for a user. We are merging two divisions and I'm looking at our templates vs. theirs to see what is different. At least I have three monitors. An instance of SolidWorks with our template on the first, their template and the second, and the list of differences on the third monitor. (though as I look at some of the differences, I don't know why was have some of the settings we are using.)
x 1821
x 2170
Here is one I've run into a few times, but I don't remember if I've posted about it here before. I have the option turned on to allow me to set dimensions as I'm sketching. If the value I enter puts the end of the line, outside diameter of a circle, etc on or close to the location to establish a relation then that relation will override the value I entered and make the dimension driven. That shouldn't happen.
x 2371
x 1986
This is very minor, but....
The symbol to rotate a drawing view points clockwise.
The number entered in the dialog rotates the view counter clockwise.
I am a GIF.
x 2585
x 1433
SPerman wrote: Wed Sep 11, 2024 2:52 pm This is very minor, but....
I am a GIF.
That is irrelevant as long as the icon is aesthetically pleasing and fun to click.
x 1821
x 2170
I am a GIF.
I'm sure you already know this, but for those who don't, if you enter a negative value it will rotate that much clockwise. I'm not making excuses, by any means, but maybe this will help someone's frustration level.
Answers: 55
x 896
I am a GIF.
Easy fix. NEVER ROTATE DRAWING VIEWS. I've been using SW since 1997 and have never needed to rotate a drawing view. I have come across drawings by others where rotated drawing views caused various weird problems though.
x 2371
x 1986
JSculley wrote: Thu Sep 12, 2024 5:29 pm Easy fix. NEVER ROTATE DRAWING VIEWS. I've been using SW since 1997 and have never needed to rotate a drawing view. I have come across drawings by others where rotated drawing views caused various weird problems though.
I follow that advice for any view with a child view. But for a single assembly view, with no dimensions, the chances of a problem are pretty low, imo.
Damo
x 187
x 227
One I hate is the suppressing of mates within the assembly when I create new configurations..!!
I cannot seem to get my head around the logic of why this happens, or which components will be affected.
It just feels so random.
Ronan
x 42
x 13
Unread post by Ronan »
Damo wrote: Thu Sep 12, 2024 6:58 pm One I hate is the suppressing of mates within the assembly when I create new configurations..!!
This might help with your confusion.
Check in the configuration properties. See if "check new features and mates" is ticked. The basically controls the suppression of mates when new parts/mates are added in another configuration.
Also if you RMB on a mate and select configure feature you can set the configs. the mate is active/suppressed in.
There is the similar RMB for components
x 1821
x 2170
I've only been using SW since 2009, but I occasionally rotate views. Most of the issues I've heard about involve one user rotating a view, and then another one comes along who isn't aware of it and problems ensue. For all general purposes I'm the only user here, and I haven't had any problems with it, so I don't see any reason to add a view in the model instead.
x 2371
x 1986
There was a problem back in 2017 or 2018 where ordinate dimensions for a child view of a rotated view had vertical and horizontal dimensions swapped.
x 2371
x 1986
Also this (2019 was a disaster of a release, IMO.)
Uncle_Hairball
x 37
x 95
Ronan wrote: Fri Sep 13, 2024 5:36 am This might help with your confusion.
If you create a new configuration, the Suppress new features and mates checkbox will match the configuration that is active when you create the new one.
Answers: 26
x 830
x 1029
Beautiful
hhhh
x 2371
x 1986
There are 2 things that really bug me when using the "replace component" command in an assembly.
1. I wish I could disable the "missing mate" popup. As often as not, I'm confused on which mate is trying to be repaired, and I make things worse instead of better. Because of that, I typically close the pup up immediately, which usually requires moving other windows out of the way to find the "X".
2. It takes a "maximized" document and un-maximizes it. I can't come up with any reason why this is necessary. I know it pisses me off that I have to go back and re-maximize the window again.
before:
after:
Answers: 26
x 830
x 1029
SPerman wrote: Tue Sep 17, 2024 3:27 pm There are 2 things that really bug me when using the "replace component" command in an assembly.
before:
after:
Re: #2
I mentioned that to Solidworks one time when I was with them, and they told me that it was a windows thing and not a solidworks thing.
x 2371
x 1986
DanPihlaja wrote: Tue Sep 17, 2024 4:03 pm Re: #2
I'm calling BS, but even so, you can't keep track of which window was on top and re-maximize it at the end?
mgibeault
x 123
x 77
Unread post by mgibeault »
SPerman wrote: Tue Sep 17, 2024 3:27 pm ... I wish I could disable the "missing mate" popup. As often as not, I'm confused on which mate is trying to be repaired, and I make things worse instead of better....
Amen!
