part sketch driven .SLDDRW lines not updating
I occasionally use .SLDDRW lines that are driven by a part sketch. Please see attached example.
Note that the notch in the lower-left corner is out of sync with the driving part sketch.
What causes this, and how is it corrected?
PSDDL_test.SLDPRT
- (52.42 KiB) Downloaded 69 times
PSDDL_test.SLDDRW
- (52.7 KiB) Downloaded 28 times
You have two over-constrained sketch relations in your drawing sketch:
They are preventing the sketch from updating correctly
Go to full postThey are preventing the sketch from updating correctly
SW 2022 SP 5.0
Windows 11
Windows 11
Re: part sketch driven .SLDDRW lines not updating
Thanks!
This (type of) problem has been bugging me for literally months.
I wonder why I wasn't seeing an error message.
SW 2022 SP 5.0
Windows 11
Windows 11
- x 1661
- x 2060
If you will set relations to show when you're working with an active sketch then ones with problems will be red or yellow instead of green, which will indicate a problem.
Hey Glenn, thanks.Glenn Schroeder wrote: ↑Tue Jul 25, 2023 3:56 pm If you will set relations to show when you're working with an active sketch then ones with problems will be red or yellow instead of green, which will indicate a problem.
Specifically, what setting would that be?
SW 2022 SP 5.0
Windows 11
Windows 11
https://help.solidworks.com/2021/englis ... le_Display
How do I toggle the display of sketch relations?
Click View Sketch Relations (View toolbar) or View > Hide/Show > Sketch Relations to toggle the display of sketch relations. If you clear View > Hide/Show > Sketch Relations , but you select a sketch entity in an open sketch, the sketch relation icons appear.
In a drawing, you have to go a step further. The only way to see the relations is to click on a sketch element on the drawing or the sketch feature of the model in the feature tree.SPerman wrote: ↑Tue Jul 25, 2023 9:01 pm https://help.solidworks.com/2021/englis ... le_Display
I noticed that as well. Thanks.
Is there a setting that will throw an error when over-definition occurs in an .SLDDRW?
SW 2022 SP 5.0
Windows 11
Windows 11
- x 1661
- x 2060
You should get one or more notifications near the bottom of your monitor on the status bar.
Nope. You either have to select the sketch or the view to see any errors.
Have you considered an alternate approach? You can create a planar surface from your sketch in the model:
and then you don't need to convert entities at all in the drawing:
Thanks for the suggestion. Sounds interesting. I've never done anything with surfacing. How would I go about it?JSculley wrote: ↑Wed Jul 26, 2023 8:44 am Nope. You either have to select the sketch or the view to see any errors.
SW 2022 SP 5.0
Windows 11
Windows 11
That's probably better than what I'm currently doing, but I think I'd still have the same problem when it comes to construction lines.
SW 2022 SP 5.0
Windows 11
Windows 11
Possibly. You should strive to eliminate sketch entities on drawings if at all possible. Perhaps if you could provide some detail on what you are trying to do that led you to this workflow, people will have ideas on a more robust and possibly better method.
- x 1661
- x 2060
I agree. Even if you don't want to create a surface or solid body with the model sketch (though you usually should), doing the sketch in a model and inserting a drawing view of it in the Drawing is almost always a better choice than sketching directly in the Drawing.
I'm using SolidWorks to create an architectural floor plan.Glenn Schroeder wrote: ↑Wed Jul 26, 2023 2:15 pm I agree. Even if you don't want to create a surface or solid body with the model sketch (though you usually should), doing the sketch in a model and inserting a drawing view of it in the Drawing is almost always a better choice than sketching directly in the Drawing.
Do I have AutoCAD? Yes. Could I use it? Yes.
I prefer the parametric, relation-driven sketching in SW, though, so I'm trying to make it work.
SW 2022 SP 5.0
Windows 11
Windows 11
- x 1661
- x 2060
I haven't done architectural plans, but I did once do a drawing of our offices to make a layout with the names, phone numbers, office numbers, etc. I still did it in a model, then imported that into the Drawing.
Glenn,Glenn Schroeder wrote: ↑Wed Jul 26, 2023 5:52 pm I haven't done architectural plans, but I did once do a drawing of our offices to make a layout with the names, phone numbers, office numbers, etc. I still did it in a model, then imported that into the Drawing.
How exactly did you do that, if I may ask.
SW 2022 SP 5.0
Windows 11
Windows 11
I did it as an assembly. Everything is a solid. This is the same process I use for everything I model. I didn't see a need to reinvent the wheel to create the plan view of our shop.
- x 1661
- x 2060
Just like @SPerman described above. In my case the walls were all a single Part file, but not a single sketch. I dislike complex sketches for several reasons.
- x 1140
- x 1947
Too many relations complicated the relationship....applies to CAD tools as wellGlenn Schroeder wrote: ↑Fri Jul 28, 2023 8:51 am Just like @SPerman described above. In my case the walls were all a single Part file, but not a single sketch. I dislike complex sketches for several reasons.
![rofl ;;](./images/smilies/e21533.gif)
