How would I move the 60" dimension from the YZ plane where it currently resides to the XY plane?
FIles attached.
How to change the plane of an isometric view .SLDDRW dimension
- ISO_dims.SLDPRT
- (46.91 KiB) Downloaded 40 times
- ISO_dims.SLDDRW
- (65.05 KiB) Downloaded 35 times
Show hidden edges and select the edges that line up with what you want when adding the dimension:
Go to full postSW 2022 SP 5.0
Windows 11
Windows 11
Re: How to change the plane of an isometric view .SLDDRW dimension
- x 1729
- x 2111
The method @JSculley recommended will work, but you can also select the top edge and bottom corner. that way you don't need to show hidden edges.
Ah, perfect.
Thanks, guys.
Thanks, guys.
SW 2022 SP 5.0
Windows 11
Windows 11
