What is the most efficient way to deal with equation errors?
Mike Gera
x 88
x 34
Unread post by Mike Gera »
I've been dealing with a lot of
"The following equations could not be evaluated because of deleted/invalid dimensions:"
...errors on a large, complex part that I've been working on.
Why I'm getting the error is no mystery: I'm deleting features that contain in-play variables.
The question becomes how to efficiently deal with the errors.
For example, how does one execute a global search for for "D2@Sketch85" (whether it's being used or not, whether it needs to be deleted or not)?
Is there a way to automatically delete all orphaned equations?
Regarding the yellow exclamation point to the left of an equation in the equation manager: what exactly does it mean? How is it corrected?
Thanks for any replies.
SW 2024 SP 5.0
Windows 11
Answers: 30
x 1214
x 1999
Re: What is the most efficient way to deal with equation errors?
You could use the "Dimension View" in the equation manger to see all dimensions, then the filter box show only the boxes that contain the dimension.
x 1638
x 1471
Setup Variables to use in equation.
Only use dimension from same sketch/feature.
Setup Variables for cross sketch/feature dimensions.
Don't do "chain" dimension: D2=D1, D3=D2, D4=D3 etc.
Make it: D2=D1, D3=D1, D4=D1
x 1759
x 2132
Frederick_Law wrote: Wed Aug 30, 2023 11:30 am Setup Variables to use in equation.
You forgot one. Use construction geometry and relations instead of equations whenever possible and practical. Which is almost all of the time for me.
x 1638
x 1471
Yes, those go in first.
Usually I'll use D1=D2 instead of equal relation because it's easier to change if they don't equal anymore.
Colinear and midpoint are great things to use.
x 2373
x 2015
Frederick_Law wrote: Wed Aug 30, 2023 11:30 am Don't do "chain" dimension: D2=D1, D3=D2, D4=D3 etc.
This is an understatement. Too many people use equations the wrong way. This is one of the worst.
x 1638
x 1471
Chain projection is next on that list.
x 2227
x 1878
Glenn Schroeder wrote: Wed Aug 30, 2023 2:00 pm Use construction geometry and relations instead of equations whenever possible and practical. Which is almost all of the time for me.
You sound like a BBQ chef who used to spend a lot of time around here. :D
x 1759
x 2132
Frederick_Law wrote: Wed Aug 30, 2023 2:16 pm Yes, those go in first.
How is deleting a relation more difficult than editing or deleting the equation?
x 1638
x 1471
I mean changing it later. Not right after they're added.
To change D2 = D1, just edit and enter new dimension.
To remove equal relation, first highlight/display and find the relation in sketch.
If it's the only equal relation, it'll be easy.
Sometimes there are a few "chain" relations. There might be 2 or more =
Mike Gera
x 88
x 34
Not to be "that guy", but is there any way you could post a .SLDPRT example of that?
SW 2024 SP 5.0
Windows 11
Mike Gera
x 88
x 34
jcapriotti wrote: Wed Aug 30, 2023 10:59 am You could use the "Dimension View" in the equation manger to see all dimensions, then the filter box show only the boxes that contain the dimension.
Ah, thanks.
On a related note, how would I search for the feature or features that use, for example, "D2@Sketch85"?
SW 2024 SP 5.0
Windows 11
Mike Gera
x 88
x 34
Frederick_Law wrote: Wed Aug 30, 2023 3:07 pm Chain projection is next on that list.
What is a chain projection?
SW 2024 SP 5.0
Windows 11
x 1638
x 1471
Project a line from sketch1 to sketch2.
Project the project line in sketch2 to sketch3.
Repeat for 10 more sketch.
This make each sketch dependent of the one before.
All they need is sketch1.
This could happen when project from feature. Instead of sketch, project from feature edge/face.
It is always much more stable when project from sketch. Even when feature is suppressed, the sketch is still there.
Answers: 25
x 812
x 980
Mike Gera wrote: Wed Aug 30, 2023 4:56 pm Not to be "that guy", but is there any way you could post a .SLDPRT example of that?
Here are a couple of different ways of doing the same thing (see attached). In all 4 scenarios, all the circles in the sketch are driven by something so that you only have to edit 1 thing to change all the circle diameters.
Please note: There are other ways to do it, but these are some examples
1) Global Variable
2) Equals Diameter dimension
3) Linked Values
4) Equals Constraint
Attachments made with SW 2022.
ShapesGlobalVariable.SLDPRT
(72.3 KiB) Downloaded 124 times
ShapesEquals.SLDPRT
(73.05 KiB) Downloaded 57 times
ShapesLinkValues.SLDPRT
(73.89 KiB) Downloaded 98 times
ShapesEqualsDiameterDim.SLDPRT
(73.84 KiB) Downloaded 124 times
