Angled dimension from vertice
- x 2189
- x 1889
Hey,
I know I can do angled dimensions from a vertice but I'm unable to achieve it. Could somone please enlighten me..? The toggle switch just doesn't show up upon selection.
From memory, I'm supposed to select the line and the vertice but I can't seem to get it to work.
Yes, with the dimension tool active, select a line/edge and a collinear point/vertex. The popup should appear.
Officially known as Creating Angular Dimensions Using an Imaginary Line
Go to full postOfficially known as Creating Angular Dimensions Using an Imaginary Line
Re: Angled dimension from vertice
I believe it's either 2 edges or 3 points.
- x 2189
- x 1889
- x 2189
- x 1889
JSculley wrote: ↑Wed Sep 06, 2023 11:20 am Yes, with the dimension tool active, select a line/edge and a collinear point/vertex. The popup should appear.
Hrmm.. Doesn't seem to work in 2023 SP3..?
Just tried it on 2023 sp3. Works ok for me. Never knew this before. Nice feature.
- x 749
- x 907
As far as I know, it only works if the point AND the line are from the same entity. (i.e., the point is the end point of the line you already selected)
Are you in a detail view in a drawing? There is a bug report against SW2023 SP3:
BR10000357494 -- Cannot dimension to imaginary lines in detail view
- x 2189
- x 1889
- Krzysztof Szpakowski
- x 58
- x 75
The point must lie on a line or its extension (colinear)DanPihlaja wrote: ↑Wed Sep 06, 2023 12:03 pm As far as I know, it only works if the point AND the line are from the same entity. (i.e., the point is the end point of the line you already selected)
Hmm... A alien doesn't know...
I'm starting to have doubts...
- x 749
- x 907
I don't understand what you are trying to say here....Krzysztof Szpakowski wrote: ↑Fri Sep 08, 2023 1:48 pm The point must lie on a line or its extension (colinear)
