Scale tool doesn't work when user isn't paying attention
x 2227
x 1878
I learned something new today about SW. (Why am I usually disappointed when that happens?)
I almost never use the scale tool, but I'm printing a 3d part with modeled threads that are a little tight. I decided the easiest way to do this would be to scale the part in X and Y. There is another diameter on the part that needs to be within a certain range, so after scaling I wanted to see what it's diameter was. That information is no longer available after scaling the part.
I am a GIF. Click me!
x 2227
x 1878
Re: Scale tool breaks measurements
It gets even worse. I decided I would create a new sketch, project the edge of that feature, and then measure that diameter. Unfortunately this projected curve is a spline. o[
x 2373
x 2015
Are you scaling faces...? I'm having a hard time understanding how only the top section scales.
x 2227
x 1878
The whole body scales. I was going to correct the pre-scale diameter of that part of the body once I knew the post-scale diameter.
x 2373
x 2015
Maybe it has to do with your scale parameters..? I'm not able to replicate your issue. If you're scaling from center of gravity and have a hole that isn't through all then I'm guessing this could be the result.
Though, I just tried that and still it worked.
Maybe I could do it for you on 2023 SP4 and save it as a parasolid..?
x 1219
x 2373
Scaling in XY is a non-uniform scale, so all of the analytical topology gets thrown out the window. (now in place of circles, you have splines). If you scaled in XYZ, I think it would work the way you expect.
Scaling is kind of a neanderthal method. If you have features, do the right thing, and change a dimension. That's why people have history-based software to begin with, right?
x 2227
x 1878
I can't duplicate it this morning either. It must be something specific about the geometry of this part. I've attached it in case anyone wants to look at it.
When I "measure" the diameter of the cylinder at one end, it will not give me a diameter.
SCALE.zip
(20.57 MiB) Downloaded 155 times
x 2227
x 1878
matt wrote: Thu Sep 21, 2023 9:28 am Scaling is kind of a neanderthal method. If you have features, do the right thing, and change a dimension. That's why people have history-based software to begin with, right?
I agree 100%.
The exception is I'm printing threads and I've found it easier to scale the part 0.5% than to try and figure out what all of those adjusted thread dimensions should be. This is the first time I've tried to do this and still cared about another diameter on the part.
Arthur NY
x 40
x 175
Unread post by Arthur NY »
Just to make sure, are your expectations that after the model is scaled that you would see dimensions that would still be able to drive the models given dimensions?
I'm imagining a Part file with a long history tree and all of the dims would then be recalculated..... just imagine those rebuild times..... WHEW!!! ><
x 2227
x 1878
No. I was expecting to use the measure tool on the OD of a cylinder (post scaling) and get a diameter measurement.
zwei
x 185
x 600
Unread post by zwei »
err
You are doing scale in X, Y with Y being the UP axis...
The cylinder is no longer round after u scale...
You should scale in X Z instead
Or scale the entire body
x 2227
x 1878
Zhen-Wei Tee wrote: Thu Sep 21, 2023 11:39 am err
Well, that explains it. Thanks for finding my issue. UU
(Don't I feel foolish.)
Answers: 55
x 878
Unread post by JSculley »
You might be better served by using the Move Face command. Here's some threads:
You can select the minor/major dia faces and the crown/root faces and use Move Face to offset them a small amount:
which gives you a slimmed down thread:
Here are two bodies showing the pre and post Move Face geometry:
x 2227
x 1878
Re: Scale tool doesn't work when user isn't paying attention
That's a great solution. Thanks for the suggestion.
TTevolve
x 86
x 159
Unread post by TTevolve »
We would 3D print solid oversize and then machine the treads, dependent on what filament we were using. Trying to get 3D printed threads is tough because of the shrinkage rates of plastic when you have thick and thin areas, which you naturally have on threads.
I also did it a few times where I would print one and then adjust the threads to print the final one I needed. We were not very concerned with the actual size of threads since the sizes are standard on machined parts, they are made off the thread call out not the actual size of the model.
Answers: 25
x 812
x 980
SPerman wrote: Thu Sep 21, 2023 11:42 am Well, that explains it. Thanks for finding my issue. UU
My favorite is how you changed to title of the post. LOL It happens to all of us. UU
x 1638
x 1471
Change it in slicer.
https://support.ultimaker.com/s/article/1667418054188
Use "slicing tolerance" to increase/reduce thread size. Exclusive for smallest size.
Also use "Adaptive layer height" to get more detail on thread.
Scaling also is easier on the slicer.
