Dimensioning Dimensions?
I have been struggling with recreating the attached drawing. I can't figure out how to dimension off of dimensions like the center of the radii to the edges, etc. Any help would be appreciated.
Re: Dimensioning Dimensions?
I ended up using Annotation > Model Items and the wizard did it all for me, including referencing dimensions to the centerpoint of the radii.
- x 2191
- x 1892
What are you having trouble with? Picking the center marks to make your dimensions?
- x 2191
- x 1892
The 180 dimension is made using the center mark of the R200 Radius.
The 6 dimension is made using the meeting points of the center mark and the edge of the flange. You can make a point coincident to the flange and then have it aligned vertically to the center mark and everything should work as needed
- Ömür Tokman
- x 972
- x 328
The dimensions do not match the figure in the picture.
I added the 3 dimensions I pointed out as estimates. What actually is the measure?
When the measurements are applied, the tip gives a different result.
