Macro for Renaming all Sketches
Programming and macros
Tera
x 511
x 91
Unread post by Tera »
I've been looking for a macro to rename all sketches in feature tree to the name of the feature it belongs to + Sketch.
Something like :
Does anyone know a macro that does something like this?
thanks.
by gupta9665 » Wed Feb 14, 2024 2:46 am
Here is a quick (dirty) macro that does the job.
Sub Mian()
Dim swApp           As SldWorks.SldWorks
Dim swPart          As SldWorks.PartDoc
Dim swFeat          As SldWorks.Feature
Dim swSubFeature    As SldWorks.Feature
Dim FeatureName     As String
Dim i               As Integer
Set swPart = swApp.ActiveDoc
Set swFeat = swPart.FirstFeature
While Not swFeat Is Nothing
  If swFeat.GetTypeName2 <> "ProfileFeature" Then
    Set swSubFeature = swFeat.GetFirstSubFeature
    While Not swSubFeature Is Nothing
     If swSubFeature.GetTypeName2 = "ProfileFeature" Then
     FeatureName = swFeat.Name & " Sketch"
     While False <> swPart.FeatureManager.IsNameUsed(swNameType_e.swFeatureName, FeatureName)
      i = i + 1
      FeatureName = swFeat.Name & " Sketch" & (i)
     Wend
     swSubFeature.Name = FeatureName
     End If
    Set swSubFeature = swSubFeature.GetNextSubFeature
    Wend
  End If
Wend
gupta9665
Answers: 26
x 446
x 483
Re: Macro for Renaming all Sketches
Unread post by gupta9665 »
There is a macro to hide all sketches in a model but I have not seen a one to rename them based on their feature name. This one will have to be made.
josh
x 25
x 561
Unread post by josh »
How would it work when sketches are shared?
Tera
x 511
x 91
josh wrote: Wed Feb 07, 2024 7:42 am How would it work when sketches are shared?
We never use shared Sketches.
But for the sake of changes in our workflow in future, I prefer it be named with the first feature that use that sketch.
If it makes any problem, renaming it to the last feature is OK as well.
thanks.
Tera
x 511
x 91
Now that it seems what I need is not possible,
is it possible to rename only the selected sketch to --> the name of the feature it belongs to + SK?
thanks again.
gupta9665
Answers: 26
x 446
x 483
Sub Mian()
Dim i               As Integer
      i = i + 1
     Wend
     End If
    Wend
  End If
Wend
x 2488
x 2101
gupta9665 wrote: Wed Feb 14, 2024 2:46 am Here is a quick (dirty) macro that does the jib.
Sub Mian()
Dim i               As Integer
      i = i + 1
     Wend
     End If
    Wend
  End If
Wend
Deepak still beeing the man UU
Tera
x 511
x 91
Thanks to both.
Will give it a try.
Tera
x 511
x 91
gupta9665 wrote: Wed Feb 14, 2024 2:46 am Here is a quick (dirty) macro that does the job.
Sub Mian()
Dim i               As Integer
      i = i + 1
     Wend
     End If
    Wend
  End If
Wend
@gupta9665 Million thanks.
Works perfect.
I only had to add a If Left(swSubFeature.Name, 6) = "Sketch" Then to prevent renaming the sketches that have already been renamed manually, and add a i = 0 after GetNextFeature to reset the counter for each feature.
I really don't know how to appreciate this favor.
Thanks again.
