Text justification
Text justification
I'm playing with my title block layouts and I cant figure out how to Center/Center justify the text in a given space.
Any tipsOK It is center top justifying!
But it is also doing something interesting. It is recognizing and NOT recognizing spaces!
It is breaking the name "ConfigurationConfiguration Configuration Configuration" into
n ConfigurationConfiguration"
That is fine. I can live with that.
Thanks for your help!
Go to full postBut it is also doing something interesting. It is recognizing and NOT recognizing spaces!
- x 2477
- x 2098
Re: Text justification
The "bounding box" of the text has to have it's center positionned at the center of the rectangle you want it centered at.
In the attached images you can see the bounding box IS center/center but the resulting text is NOT.AlexLachance wrote: ↑Thu Apr 18, 2024 3:59 pm The "bounding box" of the text has to have it's center positioned at the center of the rectangle you want it centered at.
I'm at a loss.
I have tried anchoring the box and that doesn't help....
- x 2477
- x 2098
That's odd, it seems to works for us
Do you put them in as a text field or note?
- x 2477
- x 2098
I'm not sure there is a difference! LOL
For some reason it would not allow me to attach it as a .drwdot so I changed the extension to .txt.
- TEST B SHEET FORMAT.txt
- (71.38 KiB) Downloaded 191 times
The "n" dropped off because it didn't fit in the width of your text box and there was no space before it to use as a break. Make the character size smaller or the box bigger, and it will break on the first space.
