VBA to open and CLOSE windows explorer inside a vault path
Programming and macros
mp3-250
Answers: 20
x 712
x 348
Unread post by mp3-250 »
I am trying to open a vault path from a excel macro. explorer opens as a normal window without the green folders and the pdm tabs and showing the normal yellow folders and files.
I am alredy logged into the pdm and using the standard api calls to open explorer.
Any help? what method should I use to open (and close) an explorer window pointing a vault path?
UPDATE
I was trying it from excel VBA using
ThisWorkbook.FollowHyperlink strDirectory, "", False, False
I was suggested to use instead
Dim vault As EdmVault5
   Set vault = New EdmVault5
   vault.LoginAuto "VAULTNAMEHERE", 0
   Dim location As String
   Shell "C:\WINDOWS\explorer.exe """ & vault.RootFolderPath & "", vbNormalFocus
the shell indeed opens explorer correctly inside the vault, but then I need to perform another operation:
search every explorer window and close the one inside the vault.
With the code below that would not be a problem and it works for paths like c:\ or c:\windows
Sub CloseExplorerWindowByPath(targetFolderPath As String)
   Dim explorerWindow As Object
   Dim shellWindows As Object
   Set explorerWindow = CreateObject("Shell.Application").Windows
   ' Loop through each Explorer window
   For Each explorerWindow In shellWindows
       ' Check if the window's document folder path matches the target path
       If InStr(1, explorerWindow.Document.Folder.Self.Path, targetFolderPath, vbTextCompare) > 0 Then
           ' Close the matching window
           explorerWindow.Quit
           Exit For
       End If
   Next explorerWindow
When trying that code with an explorer window opened inside the vault I get an error error 445 on explorerWindow.Document.Folder.Self.Path
The path supplyed is valid but the object does not support the path property apparently.
Testing on Win11 and Excel 2016 64 bit.
AlexB
Answers: 28
x 269
x 447
Re: vba open windows explorer inside a vault path
Unread post by AlexB »
I'm not sure if you can create a conisio url to do this or not. My quick testing did not yield consistent results but this would be my initial approach.
https://r1132100503382-eu1-3dswym.3dexp ... dYkzZfnCZg
mp3-250
Answers: 20
x 712
x 348
AlexB wrote: Mon Jun 24, 2024 8:34 am I'm not sure if you can create a conisio url to do this or not. My quick testing did not yield consistent results but this would be my initial approach.
I updated the OP.
My real problem now is how to identify the opened explorer windows and close them.
When opening a certain path inside the vault the explorer window is no more able to identify its selfpath apparently.
Answers: 55
x 883
Unread post by JSculley »
mp3-250 wrote: Tue Jun 25, 2024 4:55 pm I updated the OP.
As noted in my SWYMp reply:
Use the Windows API for this. Put this at the top of your Excel code:
Private Declare PtrSafe Function FindWindow Lib "user32" Alias "FindWindowA" (ByVal lpClassName As Any, ByVal lpWindowName As Any) As Long
Private Declare PtrSafe Function PostMessage Lib "user32" Alias "PostMessageA" (ByVal hwnd As Long, ByVal wMsg As Long, ByVal wParam As Long, ByVal lParam As Long) As Long
Private Declare PtrSafe Function GetWindowText Lib "user32" Alias "GetWindowTextA" (ByVal hwnd As Long, ByVal lpString As String, ByVal maxCount As Integer) As Integer
Private Declare PtrSafe Function GetWindowTextLength Lib "user32" Alias "GetWindowTextLengthA" (ByVal hwnd As Long) As Integer
Private Const WM_CLOSE = &H10
Then to go through all the Explorer windows and find the ones pointing into the vault, do this:
 Dim wh As Long
   Do While True
       wh = FindWindow("CabinetWClass", vbNullString)
       If wh = 0 Then Exit Do
       Dim captionLength As Long
       captionLength = GetWindowTextLength(wh) + 1 'Allow for null terminator
       Dim caption As String
       caption = String(captionLength, 0)
       GetWindowText wh, caption, captionLength
       caption = Left(caption, Len(caption) - 1) 'Remove null terminator
       If InStr(1, caption, vault.RootFolderPath) = 0 Then Exit Do
       PostMessage wh, WM_CLOSE, 0, 0
   Loop
mp3-250
Answers: 20
x 712
x 348
@JSculley Thank you very much!
I tested on a Win11 machine at work and tried to debug after my excel just froze.
Sometimes it works and close the opened explorer windows, but sometimes the loop never ends and excel stops responding.
I put a breakpoint in the loop and I noticed the same wh value with the same caption is detected over and over.
No windows opened, empty desktop, but I have 3 explorer.exe processes active.
I put 5000ms delay between opening and closing the windows.
JSculley wrote: Wed Jun 26, 2024 8:44 am As noted in my SWYMp reply:
 Dim wh As Long
   Do While True
   Loop
