Industrial Design => engineering Workflow
x 1219
x 2370
When your project needs ID type work, how do you handle it? Does the ID come from another software like Rhino or Shapr3D or Illustrator, or do you do it directly in your engineering CAD tool?
And when you get ID data from some non-engineering software source, do you just work with the imported data or do you rebuild the imported data into a live CAD engineering model?
x 1638
x 1470
Re: Industrial Design => engineering Workflow
You means those Artssy Fartssy projects? From signage, logo, industrial art, furniture etc
Start with a hand drawn illustration or a photo.
Sales Project Manager then add their illustration which look nothing like customer's.
Model it in CAD with manufacturable material/shape.
A few back and forth to get what they want to what they need.
Made sheetmetal "body armor" from a model by a college student.
Only used outside surface of the model.
DXF from Illustrator or other art software will require hours/days/weeks of "cleanup" to reduce line segments so the G-code file is small enough to run.
Autotrace on photo might have similar result.
Got an artist to check the finished weldment. Things are off according to him and we need to fix it.
Left it for a week and it's perfect when he check it again.
I think I'm way off topic .....
Basically redraw everything in CAD.
x 1758
x 2130
To illustrate the way we do it here, I will quote the letter written by one of the engineers about ten years ago, recommending one of the CAD monkeys for an award: "His most impressive ability is turning engineering sketches, hand-waving, and verbal descriptions into 3d working prototypes of new inventions and designs."
Jim Elias
x 53
x 84
Unread post by Jim Elias »
I'm not called upon to do ID. When I do projects involving ID, I'll almost always get a CAD model from the industrial designer, and I'll incorporate what I can within the confines of what the optical/mechanical stuff will allow.
BTW, almost all the industrial designers I work with use SW.
CarrieIves
x 376
x 136
Unread post by CarrieIves »
It varies on how we get the models. Sometimes we get SolidWorks models. Sometimes, we get surfaces to import. I usually remodel them so that I have something that is stable in CAD and adjusts in a way that we need.
Cadmonkeychris
x 5
x 10
Unread post by Cadmonkeychris »
If I do the ID then I go straight into Solidworks after sketching/Illustrator, the output of which might be used as backdrops to model over. Occasionally I have to use Fusion 360's sculpting mode, exporting the geometry as STEP to Solidworks.
I receive external data as scanned sketches, Illustrator, STEP, Rhino, Solidworks, STL and sometimes a Maya OBJ (architects doing product design or furniture). The quality of the 3D data determines the need to remodel. STLs and OBJ are used as backdrops, often after a trip through Modo for tidying up.
mp3-250
Answers: 20
x 702
x 347
Unread post by mp3-250 »
I did some injection molding project in the past and the imported surfaces are the bible. at least for aesthetic components for vehicles.
you can thicken them add ribs on the hidden side and propose a design modification with a well argumented reason.
Having a dummy body was easier to identify our modifications as they were always appended below.
We never rolled back the tree with 3rd party data to avoid accidental modifications downstream and to be sure we had always a controlled allowance of machinable steel in the mold. making easyer to judge if the modification required adding or removing steel from current mold design.
we were using NX which is a ton more flexible than SW thanks to Wave geometry linker and other more robust tools to swap parts, and handle non parametric geometry operations.
Lot of brute force modelling.
len_1962
x 76
x 42
Unread post by len_1962 »
Being a Model Maker i've had to be a mediator between both ID and Engineering thruout the years, first turning 2D into 3D surfaces using Surfcam CAM software because solid modeling surfacings sucked, to now using SW to surface art's farts surfaces and models. Now when SW cannot get what I need I use a range of softwares to get the shape i need, Fusion SUBD, 3D Experience XShape SUBD, Surfcam still though it's like AutoCad 12 UI, imported from whoever needs the solids (students since 2008), I also will hand shape and laser scan using DezignWorks inside SW which can extract all sorts of surfaces with geometry you can modify in SW. Then I need to make the prototype aka model via CNC, 3D printer, laser cut, vacuum form whatever is needed for ethier side ............... you guys are welcome :P UU
So Matt to your question my answer is: YES, NO, MAYBE :mrgreen:
lenny
EDIT: Matt we we need the Stirring the Pot emoj and the S H I T Hitting the fan on too like Practical Machinist Forum has.
x 1219
x 2370
len_1962 wrote: Mon Jul 22, 2024 10:18 am ...
Probably not the same icons, but here they are: [stir] and [fan]
len_1962
x 76
x 42
matt wrote: Mon Jul 22, 2024 11:51 am Probably not the same icons, but here they are: [stir] and [fan]
the S hitting the fan then face is to good!
Jim Elias
x 53
x 84
mp3-250 wrote: Mon Jul 22, 2024 5:02 am I did some injection molding project in the past and the imported surfaces are the bible. at least for aesthetic components for vehicles.
we were using NX which is a ton more flexible than SW thanks to Wake geometry linker and other more robust tools to swap parts, and handle non parametric geometry operations.
I have a lot of leash regarding how much I'm technically allowed to "adapt" the ID stuff, but there are sound reasons to put in effort to maintain the industrial designer's vision... I might be getting my next gig via an industrial designer who appreciated said effort on a past project.
in any case, the workflow you describe with reference body and freezing the ID stuff is exactly what I also use. Since I work mostly in NX, sometimes I'll create an extraction of the ID model, cut out relevant bits of this and unite them into my working model. (The SW feature trees which the ID folks create are often metastable and fall apart at the slightest parametric change anyway.)
len_1962
x 76
x 42
len_1962 wrote: Wed Jul 24, 2024 10:38 pm the S hitting the fan then face is to good!
Recording 2024-07-29 152820.mp4
(374.38 KiB) Downloaded 104 times
Arthur NY
x 40
x 175
Unread post by Arthur NY »
If there is ANY type of vector artwork that is involved in your design and manufacturing process then you will 100% benefit for purchasing a seat of Rhino3D. The goal here is to knock down a heavily segmented (.DXF) or (.SVG)....etc, file into something that is much more manageable for 2D Sketches.
- It handles 2D sketches MUCH better than Solidworks.
- Can drag and drop a PDF and it comes in vector.
- Can rebuild, simplify, vector line art in ways that save hours of time.
@Cadmonkeychris: You might want to take a look at Power Surfacing for Solidworks. Really great at SubD modeling inside of Solidworks and works with mesh data very well.
len_1962
x 76
x 42
Arthur NY wrote: Fri Aug 02, 2024 3:15 pm If there is ANY type of vector artwork that is involved in your design and manufacturing process then you will 100% benefit for purchasing a seat of Rhino3D. The goal here is to knock down a heavily segmented (.DXF) or (.SVG)....etc, file into something that is much more manageable for 2D Sketches.
There are plenty of software's that work great with DXF\DWG, SVG and vectored PDF's.
I use Corel alot.
CorelDraw
Illistrator
InkScape (FREE99)
Another software I use to create SVG or DXF from PNG, JPG is called Convertio (https://convertio.co) so i can use in SW to add to solids to either cut logos into part for the CNC or combination or CNC\Laser.
I also have Surfcam that hadles large 2D aswsome and it links to SW.
Cadmonkeychris
x 5
x 10
Arthur NY wrote: Fri Aug 02, 2024 3:15 pm --
I tried Power Surfacing early on but couldn't quite get my head around it back then. I have been on Fusion360 for a long time, so it was more convenient and cheaper to use that than buy yet more software. Maybe I will have another go when I next need the capability.
len_1962
x 76
x 42
Cadmonkeychris wrote: Tue Aug 06, 2024 6:10 am I tried Power Surfacing early on but couldn't quite get my head around it back then. I have been on Fusion360 for a long time, so it was more convenient and cheaper to use that than buy yet more software. Maybe I will have another go when I next need the capability.
There ia also another option to get Sub-D surfaces for $48 bucks a year, take this at a grain of salt, but an option anyway.
3D Experience Maker gives you X Shape for Sub-D that can be exported the sameway you'd have to via Fusion.
https://discover.solidworks.com/3dexper ... u0QAvD_BwE
Arthur NY
x 40
x 175
Technically speaking, F360 cost more over time than Power Surfacing's one time fee...... ;)
Cadmonkeychris
x 5
x 10
Arthur NY wrote: Fri Aug 09, 2024 12:59 pm Technically speaking, F360 cost more over time than Power Surfacing's one time fee...... ;)
Yes but I do use F360 for other stuff, though I won't be renewing my license later this year. After that...
len_1962 wrote: Tue Aug 06, 2024 10:39 amThere ia also another option to get Sub-D surfaces for $48 bucks a year, take this at a grain of salt, but an option anyway.
Maybe. I am supposed to have been fully employed by one of my clients but funding for the project has been inconsistent. Ideally they will be supplying all my software and equipment soon and this all becomes someone else's problem...
Ryan-3DS
x 21
x 19
Unread post by Ryan-3DS »
My experience working with real Industrial Designers—a combination of marketing analysis needs, engineering design constraints/requirements, and artistic abilities—is a bit different. The ID people I worked with were very talented and great communicators. They were the intermediates between Sales/Marketing and Engineering/Manufacturing. My experience was a give-and-take between the ID group and design. Normally we would start projects as a platform of products, and define market needs and engineering requirements. Then engineering could provide dimensions such as wheelbase and height and visual cones to the ID person. They would then start producing artwork at scale. This was generally done on a Wacom board and the images were then passed back to the CAD jockey. The image (jpg or png) was then imported into CAD, scaled to 1-1, and then the primary surfaces were created. Depending on the complexity of the project, those surfaces were used to feed the CAD assemblies and part-level designs. (using top-down design aka skeletal design principles). This used to be all done with class-A surfacing tools. Today, tools like Sub-Division modeling and lattice design significantly speed the process up. I hope that helps.
mgibeault
x 114
x 67
Unread post by mgibeault »
Ryan-3DS wrote: Wed Nov 13, 2024 10:35 am ...a combination of marketing analysis needs, engineering design constraints/requirements, and artistic abilities...
It's very sad that's often how it works. grumph
But the real answer should be "end-user needs fulfillment"
