Solidworks configurations copy derived configurations together in the same part
- Ömür Tokman
- x 987
- x 342
Hi Guys,
Solidworks configurations copy derived configurations together in the same part.
I'm looking for an easy way to do this.
As you can see in the picture below, I am creating the Metric configurations of a bolt, (manually)
I do not want to use Excel (table).
For example, when I want to create an M 8, I create the configuration and its individual sub-configurations manually. I thought of copying and pasting a configuration with its sub-configurations in the same part and changing its names and dimensions, but there is no such option.
There must be something I do not know!
I kindly request your support for a practical solution.
https://grabcad.com/omur.tokman-1/models
Ömür Tokman wrote: ↑Sat Aug 03, 2024 7:06 am Hi Guys,
Just hit CTRL C on the parent configuration, and then CTRL V on the top level. It copies the parent config and all downstream configs.
- x 790
- x 946
Re: Solidworks configurations copy derived configurations together in the same part
- Ömür Tokman
- x 987
- x 342
Thanks Dan,DanPihlaja wrote: ↑Mon Aug 05, 2024 9:18 am Just hit CTRL C on the parent configuration, and then CTRL V on the top level. It copies the parent config and all downstream configs.
I will try it tomorrow and get back to you.
Unfortunately it doesn't copy any exploded views attached to the configuration.
- x 790
- x 946
Ahh. I didn't test it far enough....
It would be really helpful if there were a way to copy exploded views.
- x 790
- x 946
Actually, you can.
While the exploded views don't copy when you copy/paste the parent config, you can select the exploded view itself and copy and paste it to a new config.
You just have to do them individually.
(I am using SW 2022, SP4)
I could swear I tried that in the past without success. Good to know how to make it work.
- Ömür Tokman
- x 987
- x 342
I tried many things but I don't know why I didn't try this.DanPihlaja wrote: ↑Mon Aug 05, 2024 9:18 am Just hit CTRL C on the parent configuration, and then CTRL V on the top level. It copies the parent config and all downstream configs.
Yes it is, it works. Thanks Dan.
