Dropping Solidworks Support
- Bradfordzzz
- x 285
- x 198
OK .... So we have decided to drop Solidworks Support altogether.
Question I have is ....
We are currently using SW 2022 SP5
I know we can go to SW2023 SP5
and I think by the time our support expires, I would be able to get SW2024 SP4
If I don't upgrade before my support expires ... am I still entitled to the latest version up until that point?
Any opinions on which of those are the most stable version?
- x 2291
- x 1965
Re: Dropping Solidworks Support
You are entitled to the latest version up until 2024 SP4, but must download it before the expiration. After the subscription expires, you cannot download anything anymore.
- Bradfordzzz
- x 285
- x 198
Thanks Alex,AlexLachance wrote: ↑Fri Aug 09, 2024 10:28 am You are entitled to the latest version up until 2024 SP4, but must download it before the expiration. After the subscription expires, you cannot download anything anymore.
I'll make sure I download all versions in that case. Good to know!
Any thoughts on stability of current version safe to be running?
- x 2291
- x 1965
We're still on 2023 SP4 as we haven't had the time to move to 2024. I've read a few good things about 2024 but I read a bunch of things that make me cringe. I think @Glenn Schroeder may be able to list a few of them.Bradfordzzz wrote: ↑Fri Aug 09, 2024 10:33 am Thanks Alex,
- Bradfordzzz
- x 285
- x 198
Thats exactly why I am so hesitant. I got burned before in a very big way.
at least with the 2022 SP5 ... its the devil we know.
like with any software YOU NEVER KNOW!
I would download every SP that way you'll have them if one is more stable than another in the future.
- Bradfordzzz
- x 285
- x 198
- x 1726
- x 2111
There are a few things I am/was unhappy with. One was the "Units" drop-down in the Custom Properties table. I had no use for it, and the only thing it did for me was get in the way and slow me down. I am happy to report that it was removed with SW2024 sp 3.AlexLachance wrote: ↑Fri Aug 09, 2024 10:40 am We're still on 2023 SP4 as we haven't had the time to move to 2024. I've read a few good things about 2024 but I read a bunch of things that make me cringe. I think @Glenn Schroeder may be able to list a few of them.
Another one was the way they "fixed" re-attaching dangling dimensions. Instead of grabbing the end of the extension line and dropping it on the new reference, as we did in the past (which worked sometimes, and sometimes not), you right-click on the dimension and select "Re-attach" from the dropdown and then click on the new reference. That seems to work fair, but there were unintended consequences. When you do that, SW doesn't always select the one you want to reattach, and I haven't found a way to switch to the other one.
And if that isn't bad enough, in the process of making that change, they removed the ability to click on the end of the extension line and make it longer or shorter. I reached out to my VAR, and they sent it up the line. It has been acknowledged as a bug, but so far it hasn't been fixed.
Those are the only issues I can think of. If others pop up I will try to remember to reply back.
The first time I dropped support, it was midway through the 2017 cycle, maybe SP3. I did manage to get SP5 via one of the resellers who has the installers available online. SP5 installed fine, even after being told during install that I did not qualify as support had stopped before the SP was released.
I do not know if this was a once-off (or twice-off) oddity, but I did manage to install the SP twice as I moved to another PC.
Cheers, Andrew Jackson.
- Bradfordzzz
- x 285
- x 198
Well these definitely aren't deal breakers for us! Thanks Glenn. Appreciate the feedback.Glenn Schroeder wrote: ↑Fri Aug 09, 2024 3:16 pm There are a few things I am/was unhappy with. One was the "Units" drop-down in the Custom Properties table. I had no use for it, and the only thing it did for me was get in the way and slow me down. I am happy to report that it was removed with SW2024 sp 3.
- Bradfordzzz
- x 285
- x 198
I doubt we will be that lucky. When it comes to Solidworks, and our current reseller, we always seem to get the short end of the stick.gristle wrote: ↑Fri Aug 09, 2024 5:46 pm The first time I dropped support, it was midway through the 2017 cycle, maybe SP3. I did manage to get SP5 via one of the resellers who has the installers available online. SP5 installed fine, even after being told during install that I did not qualify as support had stopped before the SP was released.
This is the version I am running atm and I don't hate it.Bradfordzzz wrote: ↑Fri Aug 09, 2024 10:57 am Thats exactly why I am so hesitant. I got burned before in a very big way.
IMHO it is probably the most stable since 2104 SP5. Although, a special mention for 2016, it wasnt too bad.
I have installled 2024 but as yet I do not use it for anything "mission critical".
I too have been burned. 2019 was not good for me. And 2021 was a literal dumpster fire that burned everything. (I almost quit.!!)
Download everything you like, right up until the day of your subs expiry.
Good luck.
2022 and 2023 have some very annoying, productivity killer bugs.
you need to download quite a lot of hotfix patches as well otherwise there are some parts of SW that simply do not work anymore...
if you are using PDM there are even more bugs I would gamble on 2024...
- Bradfordzzz
- x 285
- x 198
Thanks guys. Appreciate the input.
I was off subscription for about a year. During that time I needed to rebuild a computer and didn't have a full set of installation media. When I contacted the VAR, they provided the installation files.
- Bradfordzzz
- x 285
- x 198
I got the 2024 full install download from our VAR, they have them on their support website.
