how to stop "view" insert of fillet/radius centerines
Mike Gera
x 94
x 37
Unread post by Mike Gera »
In a drawing, with a view selected:
Insert > Annotations > Centerline...
Auto Insert "Select View" checked
Centerlines are being inserted for holes, which I want, but they are also being inserted for fillets/radii, which I do not want.
How do I change this?
2024-12-19 14_13_13-SOLIDWORKS Premium 2024 SP5.0 - [SW_centerline_test - Sheet1 _].png
SW 2024 SP 5.0
Windows 11
x 2470
x 2098
Re: how to stop "view" insert of fillet/radius centerines
Mike Gera wrote: Thu Dec 19, 2024 3:11 pm In a drawing, with a view selected:
Do you have this checked? "For all fillets"
Mike Gera
x 94
x 37
Thanks, Alex.
I do not have all the options that you do. I only see this:
2024-12-19 15_28_05-SOLIDWORKS Premium 2024 SP5.0 - SW_centerline_test - Sheet1.png
SW 2024 SP 5.0
Windows 11
AlexB
x 278
x 463
Unread post by AlexB »
In your drawing template, if you look at "Options -> Document Properties -> Detailing", there is a section for "Auto insert on view creation" that will put centerlines/centermarks based on your selections.
x 2470
x 2098
Mike Gera wrote: Thu Dec 19, 2024 3:29 pm Thanks, Alex.
Yeah, my apologies, in french it is not the same command. I get the same result as you with the same command.
This is most likely what you need to toggle
Edit: What AlexB said!
Answers: 26
x 821
x 1008
In the almost 20 years that I have been using Solidworks, I think I used that function twice.
Both times I tried to get it to be what I wanted without adding fluff to views that I didn't want.
Then I shelved it and have just put all my center marks in manually.
:mrgreen:
Mike Gera
x 94
x 37
AlexLachance wrote: Thu Dec 19, 2024 3:43 pm Yeah, my apologies, in french it is not the same command. I get the same result as you with the same command.
I have all of that stuff unchecked.
SW 2024 SP 5.0
Windows 11
x 220
Unread post by Dwight »
Mike Gera wrote: Thu Dec 19, 2024 4:20 pm I have all of that stuff unchecked.
Mike
Did you arrive at a solution? You do want all that stuff unchecked, and you do want to insert centerlines one by one. Are you able to do that?
