Extruded Cut - feature cannot be created
Ballfreak10
x 26
x 3
Unread post by Ballfreak10 »
Hi all,
In the attached file, I'm trying to use "SKETCH Middle Hole" to create a cut through the one body in the file. However, when I go to do so, I get the below error message, and I don't understand what it means. Anyone have any advice :)?
All help is appreciated, especially with screenshots!
Thanks in advance,
The attachment image.png is no longer available
Interior_Back.SLDPRT
(56.4 KiB) Downloaded 52 times
by AlexLachance » Mon Apr 19, 2021 12:52 pm
Ballfreak10 wrote: Mon Apr 19, 2021 12:23 pm @AlexLachance
I'm having trouble viewing the image you posted about the missing radius because it's such a tiny image. Would you mind providing a verbal description, or better yet, a larger image of the missing radius :)?
The forum is having a little temporary issue with images.
x 2305
x 1972
Re: Extruded Cut - feature cannot be created
Ballfreak10 wrote: Fri Apr 16, 2021 10:00 am Hi all,
Thanks in advance,
You're lacking a radius in your symetry
x 2305
x 1972
Excuse me, I forgot to adress the error message.
The error message is because you're doing two direction extrudes, so it's telling you that one of it's direction is not crossing any of the bodies.
Ballfreak10
x 26
x 3
Even when I uncheck Direction 2 and make sure it's in the right direction, the cut still doesn't execute.
...I apologize, but my screenshot simply will not paste onto this comment for some reason...
Ballfreak10
x 26
x 3
x 1211
x 2354
Ballfreak10 wrote: Fri Apr 16, 2021 11:25 am
You might be trying to paste the image into the Quick Reply window instead of the full editor.
x 2305
x 1972
Ballfreak10 wrote: Fri Apr 16, 2021 11:25 am Even when I uncheck Direction 2 and make sure it's in the right direction, the cut still doesn't execute.
Open up your sketch, add the radius needed that I circled, and then relaunch the extrude feature. It should automatically select the proper direction without you having to toggle anything.
Until you add the missing radius, your profile remains open and cannot create an extruded cut.
Ballfreak10
x 26
x 3
@AlexLachance
zxys001
Answers: 5
x 2294
x 989
Unread post by zxys001 »
Same... not seeing any of the attached images? :?:
...also can not read your sldprt :?:
x 2305
x 1972
Answers: 13
x 2156
x 1811
If you don't understand the concept of a closed contour, you probably need to spend more time with the tutorials.
Maybe an answer in one of these posts will help.
https://www.cadforum.net/viewtopic.php? ... 4221#p4221
https://www.cadforum.net/viewtopic.php? ... 3989#p3989
